Need quick answer-Will 2005-2010 17 inch Bullitt wheels fit 2011 GT?
Old Jun 6, 2010 | 03:20 PM
cobra97's Avatar
I can get some for a good price for the track. I do not have Brembos
Old Jun 6, 2010 | 05:31 PM
Ltngdrvr's Avatar
They should fit although you should check front brake clearance since the 2011 GT front brakes are larger.
The other thing about the 17's is that you would need a very tall sidewall tire to make the diameter match the OEM 18's that come on the car and this will be detrimental to the handling. You would need a 255/50/17 tire to get the diameter right.
Old Jun 6, 2010 | 05:54 PM
cobra97's Avatar
I actually only will be using the 2 rears for drag radials, I have 19s on the car from the factory. I am planning on using the M/T 275/40/17s or Nitto NTO5Rs same size. Thoughts?
Old Jun 6, 2010 | 06:50 PM
GRABOID's Avatar
Dont know of any reason they wouldnt fit.
Old Jun 6, 2010 | 06:58 PM
WaltM's Avatar
If you are near Philly, you can have mine @ no charge...
Old Jun 6, 2010 | 07:19 PM
GRABOID's Avatar
Dude your PM is going to EXPLODE
Old Jun 6, 2010 | 07:22 PM
cobra97's Avatar
Wow very nice gesture : )
I wish I were near Philly!!
Old Jun 6, 2010 | 08:59 PM
MontrealStang's Avatar
I do not think they will. I tried my 17" on my 2011 and the calipers rub against the ID of the wheel; the stock GT brake calipers actually rub more on the ID of my wheels than the Brembos !! My 17" are not bullits but have a slightly bigger ID than the bullits.
If you want, you can get the 05-10 caliper brackets + rotors ... your 17" bullits will fit then. The 2011 GT calipers & pads are the same as the 05-10
Old Jun 6, 2010 | 09:34 PM
Ltngdrvr's Avatar
They should fit the rear, same brakes as a 05-09 on the rear.
275/40's will be really short compared to stock.
What gear in your car?
Old Jun 7, 2010 | 06:43 AM
cobra97's Avatar
I have 3.31 gears
Old Jun 7, 2010 | 06:57 AM
cobra97's Avatar
Was this on the front or rear you tried them on?
Old Jun 7, 2010 | 07:54 AM
WaltM's Avatar
I have 275x18's on my car and there's about a 1/8" difference from stock. For 17", you have to go to a taller profile (more siderwall).
Old Jun 7, 2010 | 07:59 AM
cobra97's Avatar
Ya think 295-45-17 would work?
Old Jun 7, 2010 | 08:20 AM
WaltM's Avatar
Go here and mess around ...
http://www.rimsntires.com/specs.jsp
Old Jun 7, 2010 | 08:29 AM
cobra97's Avatar
Thank you!! I also spoke to EVO and they said it should fit fine with no problems. Thanks everyone!!!
Old Jun 7, 2010 | 09:09 AM
Bert's Avatar
appologies in advance for a minor hi-jack:
Will the "standard" 17" wheels fit on a 2010 GT or do I need something special?
I'm planning to get a set of 17" wheels with narrower/taller snow tires for the winter.
(yes it will be very painful to see "Ruby" covered with salt, but I have no choice)
Old Jun 7, 2010 | 09:26 AM
Ltngdrvr's Avatar
I have 3.31 gears
With the 3.31's the short tire could help since it would be like going with a lower gear and a tall tire so the 275/40/17 drag radials may work well for you or even the wider 315/35/17's that are about the same height.
2010 GT has the same brakes as the 05-09 so the 17's will fit no problem.
Old Jun 7, 2010 | 09:32 AM
cobra97's Avatar
I will be buying 295-45-17 brand new for 300.00 nice deal huh.
Sweet thank you- JJ @ WMS also confirmed that this is the same set up on his 2011 GT.
Old Jun 7, 2010 | 09:45 AM
m4reapr's Avatar
another thing to consider is whether the width of the DRs will work with the width of the wheels
the 17 inch stock wheels are 8 inches wide
what is the max width for DRs on these wheels?
maybe the 275s, but i doubt the 295s will work, i would think you would need a 10 inch wheel width for that
Old Jun 7, 2010 | 09:57 AM
cobra97's Avatar
I thought that, but speaking to JJ he is running the same wheels and DRs
