My new MMD short antenna broke
Had it for a week...window tint was fixed, car ran through car wash (Not by me) and all that remained was a bolt in the antenna base. Lucky a small wrench took care of that...
So a dremel to my stock antenna, and we're back in business. I will clean the end with sand paper, and plasti dip the antenna - I think the actual DIP not the spray would work better. Or maybe just black paint?
![Name: 5682100B-EE4B-40DB-B3F7-FF56B537A42A_zps8ncahg1n.jpg
Size: 82.2 KB](https://themustangsource.com/forums/attachments/f726/189572d1501260597-my-new-mmd-short-antenna-broke-5682100b-ee4b-40db-b3f7-ff56b537a42a_zps8ncahg1n.jpg)
![Name: 498B59F4-F2DB-40EA-896C-ADDC22279DB0_zpsizutueko.jpg
Size: 63.4 KB](https://themustangsource.com/forums/attachments/f726/189573d1501260597-my-new-mmd-short-antenna-broke-498b59f4-f2db-40ea-896c-addc22279db0_zpsizutueko.jpg)
![](http://i23.photobucket.com/albums/b368/earlsays/8C01DB53-EDBD-400D-94C9-57A88EAB1F8C_zpsq83nc4i9.jpg)
No popping - why would that happen? Reception was slightly degraded, however, not enough to care. I need to clean up the tip, hope that makes a difference - if not, I will go back to stock.
Former Vendor
![](http://i23.photobucket.com/albums/b368/earlsays/5682100B-EE4B-40DB-B3F7-FF56B537A42A_zps8ncahg1n.jpg)
![](http://i23.photobucket.com/albums/b368/earlsays/498B59F4-F2DB-40EA-896C-ADDC22279DB0_zpsizutueko.jpg)
Hey Earl,
Although I have to admit, your DIY job looks great, I hate to hear about the MMD antenna, it should definitely not break like that!
At your earliest convenience, shoot me over your order # and I will have your card refunded AND have a new antenna sent out to you at no cost.
Hope this helps and I'm looking forward to hearing back from you!
-Will
On the old style rod antenna if the little ball on the tip was removed it would build a static charge causing a audible pop noise to be heard while listening to the radio.
Antigini-GT/CS
10/5/15 09:43 AM
