Is my 2011 GT supposed to idle high for the first 30 sec of start up?
Old May 15, 2013 | 11:37 PM
2011 Yellow Blaze's Avatar
Just got a used 2011 gt and have noticed on cold start up that it idles at 1500 rpm's for 30 to 40 seconds then idles down to under 1000. Is that normal?
Old May 16, 2013 | 12:58 AM
Planeswalker's Avatar
Yes, it's normal.
Old May 16, 2013 | 01:45 AM
5.0 power's Avatar
Perfectly fine.
Old May 16, 2013 | 05:38 AM
Bucko's Avatar
Mine will hold that idle for about 10 to 15 seconds, then drop to below 1K.
Tony Alonso's Avatar
It's to help generate heat to enable the catalytic converters to begin working sooner and remove pollutants out of the exhaust gas.
Old May 16, 2013 | 06:24 AM
dmichaels's Avatar
Yep - you can tune it out if you remove all your cats Completely fine though, every car I've ever had does this.
Except my '94 Jeep... it wanted to pollute the world
Old May 16, 2013 | 11:06 AM
Alright thanks all. I figured it was just wanted to double check.
Old May 17, 2013 | 01:49 PM
Big Poppa's Avatar
Mine does it only when it's cold outside, or haven't been driven in several days.
Old May 18, 2013 | 01:06 AM
lsxjunkie's Avatar
I noticed if I barely blip the throttle while it's idling high, it'll settle immediately down to 1000 rpm and move down from there. I assume it's supposed to do that because it thinks I've started driving and the cats will warm while I drive.
Old May 19, 2013 | 02:29 AM
Stevedotmil's Avatar
That and to help circulate the oil to all the essentials faster before putting load on the motor while driving at the same RPM.
kennyg
Aug 14, 2023 11:45 AM
Ecostang
Nov 3, 2022 08:50 PM
Bullitt 3309
Aug 2, 2015 10:20 PM
goocher625
1994-2004 V-8
Jul 15, 2015 08:08 AM
