Mustang won’t start after heavy rain
Old May 25, 2023 | 03:26 PM
Whosthat23's Avatar
2013 mustang GT wont start after heavy rain. I felt around passenger side floor and behind kicker panel and feel no moisture. Anyone else ran into this problem?
Old May 25, 2023 | 03:30 PM
05stangkc's Avatar
How Long From Last Start to No Start! Is it a Vert? Did you Check Cabin Filter Area under Cowl Panel for Plugged Drains?? Might Also Check Door Drains!
Maybe a Long Shot But This Could Happen!
https://themustangsource.com/forums/...8/#post7075068
KC
Old May 25, 2023 | 05:02 PM
Whosthat23's Avatar
KC
No vert and It starts after sitting in the sun for a few hours.
Old May 25, 2023 | 05:10 PM
05stangkc's Avatar
Sounds Like Something is Getting {Just Wet Enough} to Cause No Start. Evidence may Be Hard To Detect! Issue Can Only get Worse as Time Goes On. I would Pull Relays & Such at SJB and See if One Stands Out as Crustier Than the Others.
KC
Old Jun 12, 2023 | 03:39 AM
MildredTruesdell's Avatar
Never heard about this issue. Have you found out why?
Spoiler
BYE BYE SPAMMER!
Old Jun 12, 2023 | 06:09 AM
Bert's Avatar
common problem is that the cowl drains get clogged, then the water overflows into the dashboard and SJB ... check the cowl drains, they are located on the firewall on the driver and passenger side, small black rubber boot-looking thing
Old Jun 12, 2023 | 12:41 PM
m05fastbackGT's Avatar
Although your passenger side floor may not show any signs of moisture, it doesn't necessarily mean that your SJB wasn't exposed to water damage... If your drain plugs are clogged as the others have suggested? it's very possible you're carpeting on your passenger side floor has either dried out since first being exposed or wasn't severely exposed enough, to begin with... Therefore, check your drain plugs as suggested above...
If the drain plugs are not clogged up, then check your door plugs, especially on your passenger side... If no water has accumulated inside the doors, then I would recommend as the next troubleshooting step, to connect a hand-held scanning device to your vehicle's OBDII port and scan for any potential trouble codes... If you do not own or have access to a hand-held scanning device, you can always take your car to any local Advance Auto Parts location, and they will allow you to connect one of their hand-held scanners to your vehicle on site at no charge...
Old Jul 15, 2023 | 12:14 AM
MarkJohnson's Avatar
Thats weird. Have you found the reason? When I couldn't find any essay samples online, a friend suggested a site. SPAMMER on this link It has a variety of essay examples on sociology that are helping me with my assignment. Give it a try!
Old Jul 18, 2023 | 09:41 AM
05stangkc's Avatar
Spoiler
BYE BYE SPAMMER!
See Ya!
Kc
Tommy123
Aftermarket 2005+ Mustangs
May 26, 2019 10:13 AM
Todd72
Feb 18, 2014 10:27 AM
The Hamer
Jan 31, 2013 12:16 AM
2013FORD
Oct 25, 2012 02:46 PM
pittperson
14
Jul 11, 2005 09:11 AM
