Mustang with brembo brakes pulling to the left
I have been noticing it lately it only happens at low speed aka pulling up to a stop light and on **** roads with pothole and dips smooth roads are no issues any thoughts and it pull to the right is this normal
Have not noticed any pull with mine thankfully... But only 1000 miles on mine. I hear a slight squeak... Sounds like rear brakes on light braking. But stops straight as an arrow.
If its pulling it could be a slight alignment issue or one of the brake calipers or lines has a bit of air so it's not getting as much pressure as other calipers. Have you bled all the brakes and tried re-bedding the pads?
First, check air pressure, then inspect the tires. If you don't find anything on the tires, odd wear patterns indicating alignment, etc, then maybe to a front/rear tire rotation, re-test. Sometimes tires can be slightly taller or shorter, and the rear tires will usually be worn nice and even and flat from the solid axle. If still happening, re-bed the pads, several procedures on the web for that. If problem still persists, take it to Ford and have them inspect the brakes and bleed the lines.
Please make an appointment with your dealers to get them checked out as soon as possible. Then PM me with your dealer, mileage, VIN, full name, and best daytime number so I can escalate this to the customer service manager for your area.
Deysha
Once i have a date i'll PM you the details.
Thanks!
RRRoamer
1/19/17 05:27 PM
Michael Follett
7/24/15 06:58 AM
AMWill
7/20/15 08:40 AM
