Mustang with brembo brakes pulling to the left
Old Jul 3, 2013 | 10:00 AM
Gogoggansgo's Avatar
I have been noticing it lately it only happens at low speed aka pulling up to a stop light and on **** roads with pothole and dips smooth roads are no issues any thoughts and it pull to the right is this normal
Old Jul 3, 2013 | 03:22 PM
Sieran's Avatar
Mine pulls to the right under heavy/moderate braking. Does not seem to matter which road.
Old Jul 3, 2013 | 03:28 PM
14Glassback's Avatar
Have not noticed any pull with mine thankfully... But only 1000 miles on mine. I hear a slight squeak... Sounds like rear brakes on light braking. But stops straight as an arrow.
Old Jul 4, 2013 | 06:15 AM
dmichaels's Avatar
If its pulling it could be a slight alignment issue or one of the brake calipers or lines has a bit of air so it's not getting as much pressure as other calipers. Have you bled all the brakes and tried re-bedding the pads?
Old Jul 5, 2013 | 03:48 AM
kn7671's Avatar
Ditto - Exactly what I would be looking at.
First, check air pressure, then inspect the tires. If you don't find anything on the tires, odd wear patterns indicating alignment, etc, then maybe to a front/rear tire rotation, re-test. Sometimes tires can be slightly taller or shorter, and the rear tires will usually be worn nice and even and flat from the solid axle. If still happening, re-bed the pads, several procedures on the web for that. If problem still persists, take it to Ford and have them inspect the brakes and bleed the lines.
Old Jul 5, 2013 | 07:56 AM
FordService's Avatar
Hi guys,
Please make an appointment with your dealers to get them checked out as soon as possible. Then PM me with your dealer, mileage, VIN, full name, and best daytime number so I can escalate this to the customer service manager for your area.
Deysha
Old Jul 5, 2013 | 09:01 AM
Sieran's Avatar
Originally Posted by FordService
Hi guys,
Deysha
Going to hold out a few more weeks so i can get the 5k service done at the same time. I'll make my punch list and hand it over to them when i make the appointment.
Once i have a date i'll PM you the details.
Thanks!
Old Jul 8, 2013 | 08:41 AM
Thanks!
Great! I'll be on the look out for your PM, Sieran.
Deysha
Old Jul 9, 2013 | 08:33 AM
Brandon302's Avatar
So it pulls to the right on normal roads, or roads with ruts?
Jim74656
May 1, 2023 02:15 AM
RRRoamer
Jan 19, 2017 05:27 PM
Michael Follett
Jul 24, 2015 06:58 AM
AMWill
Jul 20, 2015 08:40 AM
Coyote5-0
Jul 17, 2015 03:47 PM
