Lightweight battery?
Old Jun 1, 2013 | 12:03 PM
dmichaels's Avatar
In my previous car I had a lightweight battery that I used in the summer for track season. I know some cars (corvettes) react... Strangely... To lightweight and low amperage batteries (corvettes apparently will either cease to start or lock the steering wheel, forget which it is) wondering if anyone knows of any issues with lightweight batteries in mustangs? I like saving 35 lbs or so up front!
Old Jun 1, 2013 | 12:11 PM
Brandon302's Avatar
That sounds like an issue with amperage and not the weight of the battery. I would think as long as you get a battery with the appropriate cold cranking amps you should have no issues.
Old Jun 1, 2013 | 12:15 PM
dmichaels's Avatar
Yes agreed its the amperage that is the issue. Not the fact it's light... Of course the light batteries have far fewer cca's than OEM batteries
Old Jun 1, 2013 | 12:28 PM
Brandon302's Avatar
Not entirely true, check out Braille batteries.
Old Jun 1, 2013 | 12:53 PM
dmichaels's Avatar
I had a Braille previously. Worked great for me, although they seem to over rate their cca's
Old Jun 1, 2013 | 01:15 PM
Brailles also don't last very long.
Old Jun 1, 2013 | 01:19 PM
Brandon302's Avatar
Who does make a long lasting performance light weight battery.
Old Jun 1, 2013 | 02:55 PM
dmichaels's Avatar
I also had a Deka EXT14 before, which I used through the winter. It was fine unless the car sat for more than a week in the cold (like when I traveled...) and it weighed a total of 12 lbs. I would buy again
Had only 200 or so CCA's, but it was plenty to start an S4
Old Jun 3, 2013 | 10:50 AM
ConeBoss's Avatar
I have had one of these in my STi...which has a beefy alpine Amp in it for over a year DD use and it works great. Not too spendy either...
http://www.batterycentralmall.com/Ba...-S_Series.html
They make a wide range that have various weights and capacities.
What you loose with most light weight batteries is reserve capacity...so don't go bumping the stereo for long with the engine off.
BTW, you wont be saving 35lbs...it will be more like 20 unless, assuming you have the same stock battery I do...it weighs about 38lbs.
Unless you can afford to get a battery like this one...
http://www.batterycentralmall.com/Ba...-L_series.html
Old Jun 3, 2013 | 01:14 PM
dmichaels's Avatar
Ok 35 lbs may be a bit optimistic... Haha. I think my old car had about a 45 lb battery tho so I saved about 30 lbs there. But 38-12 is still a 26 lb weight savings! Wish I had budget for one of those super light batteries!
Uofmrampage
Aug 2, 2022 02:55 PM
lakersfreak
Jun 13, 2022 12:29 AM
CiniZter
25
Apr 28, 2016 05:41 PM
PonyMuscletang13
Sep 29, 2015 09:40 AM
PonyMuscletang13
Sep 24, 2015 01:40 PM
