koni str.t + steeda sports + MM mounts
I just got done installing koni str.t + steeda sports + mm mounts and anytime i go over a bump or compress the body down i hear the shock (or the mount plate) hitting the under part of the fender well.
Has anyone ever experienced this?
I followed the instructions that came with the mounts.
please help, i am afraid to take her out for a spin because they are hitting pretty hard and making some pretty loud noise.
Just so you guys know i got a call back from Maximum Motorsports (nice guy and quick response) and it turns out that all str.t struts are the old long bolt 3" model and will require the spacers that come with the MM mounts.
I guess i just figure mine would be 2011+ struts and should have done more research.
Don't worry my punishment is i get to take the fronts off again and do it all over.
That punishment sucked
Just an FYI for anyone else reading the thread..
READ THE INSTRUCTIONS ALL THE WAY THROUGH BEFORE YOU EVEN PICK UP A WRENCH.
9/24/15 08:15 PM
