*Knock knock*who's there? its me drive belt
Old Dec 15, 2013 | 10:49 PM
HizliBullet's Avatar
I see this problem is very wide spread in this community I thought I'd share mine. I didn't pay much attention until co-workers began pointing out a loud tapping sound.. Booked appointment for tomorrow to show this to service,I was able to record it just as tsb mentions as "warm and idle engine". is this what most of us are experiencing?
part 2. around 0:28 mark I lay on the floor to record under carriage.. knocking is coming from the passenger side bottom..
Old Dec 15, 2013 | 11:21 PM
PonyMuscletang13's Avatar
Did you get this noise after an oil change?
Old Dec 16, 2013 | 06:03 AM
David Young's Avatar
One would think, Ford would have had this problem fixed for the 2012's .
Old Dec 16, 2013 | 07:01 PM
Yeah after 4th oil change
Old Dec 16, 2013 | 07:06 PM
scramblerider5's Avatar
Hope it gets fixed soon
Old Dec 16, 2013 | 07:42 PM
TheReaper's Avatar
A/C stretchy belt, been there done that.
Old Dec 17, 2013 | 05:51 AM
luzstang's Avatar
i just went through this (had the same noise), in my case it was the lifters...
Old Dec 18, 2013 | 11:25 AM
FordServiceCA's Avatar
CURRENTLY NOT ACTIVE ON THIS SITE DO NOT USE PM FEATURE!
Mustang 5.0 tsb issue? - YouTube
2012 Mustang 5.0 engine knock (tsb 12-8-14?) - YouTube
Hi HizliBullet,
Since you got your oil changed, were you able to get your 'Stang at the dealer to get this checked out? If not, please make an appointment with them and once that is done send me your appointment date/time, VIN, odometer reading, full name, servicing dealer, and best daytime phone number. I'll see what I can do.
Bianca
Old Dec 20, 2013 | 06:41 PM
TheReaper's Avatar
Update ????????????
Old Sep 2, 2014 | 02:10 PM
just an update on this issue ive been having.. i went to ford 2 times, they said they replaced the bolt holding a pulley in the front (no sense) but the ticking is still there..
Old Sep 10, 2014 | 07:16 PM
pminri's Avatar
This knock just started about a week ago on my 2014 GT. I have 11500 miles and I can only hear it after the engine is warm. It is not as loud as the one in the video but each day it gets a little bit worse. I drive 18 miles to work (mixed highway and backroads) and once I get to work (or home) I put the car in neutral (manual trans), windows down and I can here it from idle to about 1500 rpm. If I push the clutch in I can feel it in the clutch pedal. If I tap the gas from idle to 1200 and when it starts to fall back to idle it is most noticeable. I have read on the internet that it has been documented for 11 and 12 5.0 engines but not a 14. The posts before mine seem the same, but nobody posted if they got theirs fixed and what was the fix (except the one with the lifter issue)??
Any help is appreciated. I can't get to the dealer until Friday to see what they say.
Old Sep 11, 2014 | 06:48 AM
JoeMidnight's Avatar
To be completely honest with you.... keep taking it back. If it gets to the point where they are telling you, its "normal" take it to another dealership and keep doing so until you have resolution... that's what I would do.
Old Sep 11, 2014 | 10:59 AM
KIOT5-0's Avatar
A/C stretchy belt TSB 12-8-14. It took me 5 visits and 2 dealers to get it taken care of. They have to remove the front engine cover and and install a tensioner.
BR3Z-8620-DA Kit-Drive Belt - GT Engine Front Cover, A/C
BR3Z-6019-G Front Cover Compressor Drive Belt XW4Z-6700-AA Crankshaft Seal - Front
CR3Z-7R081-D Tube Assembly Transmission Idler Pulley, Tensioner,
Cooler And Drive Belt
FromZto5
75
Oct 5, 2015 02:27 PM
Evil_Capri
Sep 11, 2015 08:39 AM
oldnjguy
Sep 10, 2015 02:39 PM
Road_Runner
Sep 10, 2015 01:14 PM
Road_Runner
Sep 10, 2015 11:28 AM
