i need to order some 2013 GT500 parts, is this where i ask?
im not sure who can do orders here from ford and who can give us discounts, but i was hoping i can get some parts ordered .
looking for 2 mufflers from 2013 GT500 i think part #5230 LH and RH
and 2013 GT500 rear bottom defuser, i think correct part # is 17F828B
If you have a regular GT I don't think you can just get the rear diffuser and swap out. I believe you would have to cut the original area out. the Cali special and Boss have the removable piece that can be swapped with the GT500 piece.
I am sure someone will be along shortly to correct this if I am wrong.
You need the full rear fascia to install either a Boss/CS or GT500 diffuser. I posted part numbers for the GT500 mufflers in the retrofit thread, and the diffuser part number may not be 100% correct. It's definitely not as cheap to swap out as the 10-12 cars.
It will work if you want it to, at least with the boss diffuser:
A brain is required though
http://www.google.com/url?sa=t&sourc...H1x12L1N2Eyodw
Originally Posted by BOSS302R
things can always be adjusted
Diode Dynamics
6/12/18 03:26 PM
