Hub Centering Rings, needed or not?
Old 2/25/14 | 12:02 PM
Dean Martin's Avatar
Originally Posted by FromZto5
From what I understand, the purpose of the grease/anti-seize compound is not for installing, but for removal. In other words, my intent with this rim set, is to remove them every "off season" (in Iowa speak, that's winter). So, I have read/heard that at times, the rings get bonded to the hub for whatever reason, be it rust, heat, dirt, etc... So the anti-seize/grease would just help get it off. Especially since I will be doing that 2x a year, (remove in winter, install in spring).
Anyone else on here with my same situation, or has used a type of grease/anti-seize compound?
Maybe if you were using aluminum versions, but probably not needed with plastic?? I could see having some corrosion with the dissimilar metal of the wheel hub.
Anyway I drive like 28K miles a year and rotate frequently so nothing ever really has a chance to seize up much.
Hopefully someone else can chime in....
Old 2/25/14 | 12:16 PM
Yeah, I have heard of instances where plastic/polycarbonate rings end up being disintegrated upon next removal. As for the reason(s) why, I am unaware.
But yes, the rings I have ordered and on the way are aluminum.
Old 2/25/14 | 12:30 PM
Originally Posted by Jay@Hypermotive
I picked mine up from next level motoring NLMotoring.com. They're dirt cheap so I bought like 30 of them.
Thanx! I've been needing some for my winter car studded wheel set.
Old 2/25/14 | 12:35 PM
^ Cyd... try Discount Tire Direct too. Great customer service, 5 bucks, ANY size, free shipping.
Old 2/25/14 | 12:50 PM
Old 2/25/14 | 03:28 PM
Horspla's Avatar
Aluminum rings were a good choice. If you use anti-seize don't go crazy with the stuff. It has a way of appearing in places you least expect...I'm convinced that stuff has legs and can walk! It's also hellsih to clean up. A light coating of good quality grease would work well also.
John
Old 2/25/14 | 04:22 PM
Jay@Hypermotive's Avatar
Former Vendor
Nice, didn't even think about that.
Old 2/26/14 | 05:12 PM
Look what just arrived! Now if only the weather would cooperate, I can start to mount these bad boys. I'll do a test fit on the Milans tonight... That part I can do without going in the cold garage and taking off the current brembo rims.
Attached Thumbnails Hub Centering Rings, needed or not?-image-3406535817.jpg
Old 2/26/14 | 06:18 PM
Perfect fit. No interference issues. Pics are before ring placement and after ring placement.
Attached Thumbnails Hub Centering Rings, needed or not?-image-1594205737.jpg   Hub Centering Rings, needed or not?-image-1420405963.jpg
AMWill
7/20/15 08:40 AM
Quick Reply: Hub Centering Rings, needed or not?
