How to store for the Winter?
Old Nov 5, 2012 | 10:38 AM
11SHELBYGT500's Avatar
My Alaska car. I asked myself every year why I lived in such a cold @ss place. It broke my heart to only be able to drive it half a year. (If lucky)
:verynice: always liked saleens. Did you buy it new?
Old Nov 5, 2012 | 10:45 AM
Getportfolio's Avatar
Thanks. I stored it in a heated unit and just disconnected the battery. We often got into the negative temps there.
Lol That first crank in the spring was so hard on the car! Worst sound you ever heard. The car shook, water sprayed out of the pipes, and the alarm came on, sounded like a weak kitten.
Anyway I sure I wish I knew what I do now. The post up a bit is excellent info. Certainly the way to go.
Old Nov 10, 2012 | 09:15 PM
dontOverSteer's Avatar
Okay. I bought all of the supplies I felt I'd need. I was going through my checklists of to-dos, and got to adding STA-BIL. And then I encountered a problem.
The capless gas tank needs an actual gas pump nozzle to open it up. I tried using a funnel, and using portable gas tank nozzles, but none of them did the job. I don't know how to add the STA-BIL with this capless design.
Old Nov 11, 2012 | 01:22 AM
mopar?'s Avatar
Check your trunk
Theres a funnel that does the job back there.
Old Nov 11, 2012 | 08:24 AM
TheDivaDanielle's Avatar
This is retarded. This isn't 1957, nor are the cars that old either.
Step one.
Park in Garage.
Step two.
Pull out of Garage
My father actually has a genuine classic. (1955 Bel-Air). All he does is park it in the garage, and put it on jackstands. that's it. No voodoo, no stabil, nothing special.
Old Nov 11, 2012 | 08:40 AM
montreal ponies's Avatar
Here is what i've been doing with my last five 'Stangs.
-Change oil & filter
-Top off gas
-Add Sta-bil and run engine for 10 minutes.
-Wash
-Increase tire pressure to 35-37 psi
-disconnect battery and use a battery tender.
-mine sits in a heated garage, but i still start her up every once in a while for 15-20 minutes.
Old Nov 11, 2012 | 08:49 AM
MJN's Avatar
MJN
Mine is about the same. Also about the same for my Dad's 64 Car. Most tips are shared or used from Haggerty Ins.
Change oil
Stabil in tank and drive a bit so in the lines
Clean
New for this year I have it up on Flat Stoppers
Maintainer Charger (CTEK Charger)
Car Cover, and with zip lock baggies on the exhaust pipes
Insurace set for storage
Old Nov 11, 2012 | 04:26 PM
bee bop's Avatar
Sheesh! This seems like a lot of trouble to me.
Here what I do.
1. drive it.
2. drive it.
3. if it snows slow down.
Been doing this since I got my first Stang in 1985.
Old Nov 11, 2012 | 07:33 PM
Originally Posted by mopar?
Check your trunk
Good call. I checked the trunk the day I took the car home, and haven't lifted the carpet since then. Guess I forgot about that.
Old Nov 12, 2012 | 08:20 AM
JCStang's Avatar
Mine has been detailed and under the covers until next spring....it's gonna be a long winter....
Old Nov 13, 2012 | 01:51 PM
Bucko's Avatar
Easy winter storage....head south!
I feel for you folks up north that have to put up with the snow, salt, and nasty weather.
Old Nov 17, 2012 | 08:48 PM
MustangMark721's Avatar
had to store mine too. i got a covercraft car cover from car covers direct, they'll tell you what kind of cover you need for where and how long your storing it and I got 10% because it was custom!
Mpaps
Oct 11, 2017 08:06 PM
Cobiecane
Oct 23, 2015 08:44 AM
dave07
Oct 8, 2015 03:14 PM
Steve@CJPP
Sep 3, 2015 10:43 AM
