How to Raise the Front of the Car
Old Jun 1, 2018 | 10:32 AM
jim010's Avatar
I'm going to post this here to see if I get more responses.
I put in Boss 302 coil springs all around and Koni Yellow struts. I used the struts for 05 - 09 cars with the GT500 strut mounts.
The car, of course, dropped in the front, and only slightly in the back to produce the same rake the Boss 302 has.
But I am finding that the front is too low (scrapping), and I am not liking the rake either.
Looking for solutions. I like the increased spring rate of the Boss coils, so I would rather not put the old ones back in.
Old Jun 1, 2018 | 11:00 AM
5.M0NSTER's Avatar
Substitute front springs with lower drop but still increased spring rate springs? I think Roush makes 1/2" drop springs along with a handful of manufacturers.
Old Jun 1, 2018 | 11:35 AM
jim010's Avatar
No, I don't want to have the front dropped. I want it raised back up again.
Old Jun 1, 2018 | 04:06 PM
m05fastbackGT's Avatar
If Roush offers 1/2" rear springs? that might be just enough to level out your car and raise your front end. Otherwise, if they don't offer 1/2" rear springs, look into 1 inch instead
Old Jun 1, 2018 | 04:14 PM
jim010's Avatar
That's my back up plan.
I know everyone want to lower the cars, and I am going against the grain by wanting to raise it back to stock.
Old Jun 2, 2018 | 09:30 PM
5.M0NSTER's Avatar
I say stop messing around and get a suspension system designed for the car. Roush does make a 1/2" drop kit for the S197. Instead of a custom Frankenstein creation get a kit actually designed to work well together. Your handling will thank you.
https://www.americanmuscle.com/roush...wBlA&gclsrc=ds
You can just get the springs also.
Old Jun 3, 2018 | 07:48 AM
jim010's Avatar
Sigh .... no one listens...
I DO NOT WANT a drop. I want to have the increased spring rates, but not the drop. I hate the scrapping I'm getting over steep transitions with the drop I currently have and want it raised back to stock WITHOUT reverting back to the stock springs.
never mind. ...
Old Jun 3, 2018 | 08:12 AM
5.M0NSTER's Avatar
then go back to stock setup and quit whining already
Old Jun 3, 2018 | 08:25 AM
jim010's Avatar
Yeah .... whatever
Old Jun 3, 2018 | 08:28 AM
EF1's Avatar
EF1
I see 3 options without lowering the rear to level the car:
1) Put the stock springs back in and lose the higher rates to get stock ride height.
2) Buy custom springs with the increased rate, but stock length.
3) Since you used the 2005-2009 GT 500 mounts you are a little lower than you would have been with struts/mounts for the 2010-2014 cars. You can switch struts and mounts to the newer design and get back part of the drop and keep your springs.
Old Jun 3, 2018 | 08:31 AM
Siber Express's Avatar
The 05-10 Struts are 1/2 lower with the GT500 mounts, I do not no if the regular mount is higher but I know there were some talking about the 11-14 struts were higher because of this.
Old Jun 3, 2018 | 08:37 AM
EF1's Avatar
EF1
Oh one more idea, You could go to a larger diameter tire and raise the whole car a little, while filling up the wheel wells a bit more.
Old Jun 4, 2018 | 07:33 AM
Bert's Avatar
Originally Posted by jim010
Sigh .... no one listens....
everyone is listening and trying to help you; and the best we can do is "if it was my car, I would . . . "
sounds like the 05-10 struts and GT500 mounts is the issue and reversing that would be the fix
Old Jun 4, 2018 | 08:11 AM
jim010's Avatar
Thanks for the input guys.
I am leaning towards putting the front stock springs back in. MAYBE I'll trade the front Konis for 10 - 14 and use the Boss 302 strut mount (I think they are a harder rubber?)
Funny I can find these:
https://www.steeda.com/steeda-mustan...-997-0163.html
https://www.steeda.com/Steeda-S550-M...9_p_12604.html
But nothing for S197
Old Jun 22, 2018 | 09:23 AM
jim010's Avatar
OK, I am about ready to throw some money at this but not until I know for certain it will work:
Siber,
I think I will exchange the Konis I currently have on there for 11-14 Konis and the Boss 302 mounts but not finding confirmation on a couple things. Maybe I'm not looking hard enough ...
1) are the 07 - 09 GT500 strut mounts causing lowering for sure?
2) are the Boss 302 strut mounts any better than the stock mounts?
Old Jun 24, 2018 | 08:14 AM
I never did the GT500 Mounts, but seems like everywhere I read they were 1/2 inch lower than the stock mounts on the 11-14 Mustang.
The 302 mounts are a little tighter than the stock, I have those on mine and got the call from Tasca that they won't fit my car when I ordered them, they fit.
BTW here is another option, supposed to be 1 inch with what you have now
https://www.speedwaymotors.com/Mr-Ga...er,287900.html
Old Jun 24, 2018 | 04:39 PM
jim010's Avatar
I've been looking for that, Siber! Couldn't find anything to fit the S197.
that certainly is the cheapest way to go!
Do you think I'll lose any road feel? It's either this or do the front suspension all over again
Old Jun 24, 2018 | 08:19 PM
You might loose a little around the frost heaves. I had something similar on my 73 Cougar since it went to low when we cut the springs and it actually still handles quite well. And Truthfully I think they were Mr Gasket also, got them at Super Shops when they were the Performance store to go to.
Old Jun 25, 2018 | 11:40 AM
jim010's Avatar
Can't use it, ****. Not big enough to fit in the spaces between the coils.
dustindu4
Jan 14, 2006 09:19 AM
HastaLaVista
Nov 11, 2005 03:35 PM
racerx
12
Jun 17, 2005 05:53 PM
