Hope I didn't screw anything up
Old May 19, 2014 | 08:32 AM
Ace Red's Avatar
So there I was.... WOT, going from 4th gear to 5th. Somehow I missed 5th and pushed it into third let out the clutch and locked up the rear tires (pretty good chirp) I immediately pushed the clutch in and put it in 5th or 6th but when I let my foot off the clutch it only went half way back.
Pushed the clutch in again, put it in neutral, glided for a bit, put it back into 6th gear and then it came back all the way out.
Prognosis?
Everything seems to be working fine now. I don't even think I saw the red rev limiter kick in although I could have missed it. Kind of took me for a surprise/scary while merging/surging ahead in traffic.
Old May 19, 2014 | 09:13 AM
devilcaninex's Avatar
Glad you didn't hit anyone
Old May 19, 2014 | 10:07 AM
Ace Red's Avatar
That wasn't even remotely a possibility at the time.
Old May 19, 2014 | 10:30 AM
5.M0NSTER's Avatar
Wow, that's usually called "the money shift". Mainly because it's an expensive mistake typically. But if you damaged something you'd know it by now. Take a look at all your belts. A fried of mine did the exact same thing at a track day last year in his honda, and blew off one of the belts. How high in the RPM band were you when shifting to 5th? The rev limit probably did kick in and saved you.
If you were low enough in the RPM range then you probably didn't bounce off the rev limiter. The chirp is expected in those situation, but that still won't do any damage to your engine.
Its always one of my biggest worries. I take my time to be sure I'm in the right gear before I release the clutch. I think you may have been lucky.
Old May 19, 2014 | 10:40 AM
pressman43's Avatar
MGW will fix that problem. They are so awesome I'm kicking myself for not doing it sooner.
Old May 19, 2014 | 11:06 AM
5.M0NSTER's Avatar
Really? I know MGW is a great shifter, but if you put it in 3rd it will go in 3rd. I doubt MGW will be able to save you if you don't push the shifter over to the right far enough.
In this case the only thing that can save you would be an automatic
Old May 19, 2014 | 11:34 AM
pressman43's Avatar
I see what you mean and yes if you don't know to push to the right get an automatic. I was referring to the fact that the MGW takes a little of the slop out of the factory shifter and gives you a more precise route through the gears.
Old May 19, 2014 | 12:12 PM
I had a POS car a long time ago and I use to go from 3 to 1 for some truly spectacular stunt driving.
Old May 19, 2014 | 01:41 PM
Ace Red's Avatar
MGW is on my hot list of items. These tranny's can be a bear from 4th to 5th when your on it. I was more concerned why the clutch pedal didn't come back up right away. Motor seems fine. Just not sure if I could have caused internal trans/clutch issues that will show up later.
oneeyedgiant
Nov 16, 2015 12:23 PM
dblhelx
Oct 6, 2015 08:08 PM
boz
Oct 1, 2015 04:47 PM
