The hell just happened, losing to a 14' challenger rt
Old Apr 19, 2017 | 09:34 AM
Winkawak's Avatar
Did a 40 mph pull with a friend who owns a stock 14' challenger rt (372hp/400tq). When i floored the gas the car hesitated for a good second or two before taking off, while rt was almost instant when floored leaving me a car length behind the rt. Im still on stock tune and been driving slow lately due to traffic. Im not sure if its the adaptive learning thats confused when i floored it because im pretty **** sure my car suppose to be the faster one lol. Ima get my rematch soon.
Old Apr 19, 2017 | 01:36 PM
GrnT's Avatar
Drive by wire?
Old Apr 19, 2017 | 01:48 PM
ElkGroveFordGuy's Avatar
Maybe he just has a quicker reaction!
Old Apr 19, 2017 | 02:04 PM
dmichaels's Avatar
shoulda bought the manual
Old Apr 19, 2017 | 04:48 PM
EF1's Avatar
EF1
A tune seems to shorten the throttle lag quite a bit.
Old Apr 19, 2017 | 05:16 PM
All joking aside a throttle relearn can fix that a lot as well.
It can make a big difference.
But yes a tune will really fix it!
Old Apr 19, 2017 | 11:14 PM
NacsMXer's Avatar
If it was from a 40 roll like you said you should have used the Select Shift to lock the trans in 2nd. Punch the gas on the hit and the car will pull instantly like a manual without having to wait/hesitate do downshift and then start pulling. This is where the Select Shift shines. Then a moment before you reach redline in 2nd, just bump the shifter forward into D and let the auto trans take over.
Old Apr 20, 2017 | 03:44 AM
David Young's Avatar
If the GT is like the V6. Pop the hood and look over to your left (passenger side). Open the long fuse box. Pull fuse number 47 and keep it out for an hour or two. This resets the adaptive learning. I do mine once a month to keep things fresh
Old Apr 20, 2017 | 05:42 AM
Bert's Avatar
Originally Posted by Winkawak
. . . When i floored the gas the car hesitated for a good second or two before taking off, . . . . .
yep, sounds like a slow downshift from the auto to me
Old Apr 20, 2017 | 09:23 AM
tourer's Avatar
True, My 2013 had a bad lag problem, new 93 octane tune, Lag is gone.
Old Apr 20, 2017 | 01:40 PM
kylerohde's Avatar
What kind of racetrack were you at that you got to drag from a 40 mph roll?
Old Apr 20, 2017 | 03:04 PM
dusman59's Avatar
Probably on a back country road in Mexico. I hear the cartels use a lot of R/T's down there.
Old Apr 20, 2017 | 04:34 PM
A guy I work with has a 14 charger RT it rund 13.5 in the 1\4 mile.
they are not slow!
His is all stock.
Old Apr 20, 2017 | 06:21 PM
TheReaper's Avatar
I say it was driver error.
Old Apr 21, 2017 | 05:16 AM
MRGTX's Avatar
Are you sure it was a 5.7?
Are you sure it was stock?
Are you sure this person was actually your friend?
Are you sure you didn't just dream this scenario?
As cool as they are, there's no way a stock 5.7L Challenger R/T should be able to keep up with a Coyote Mustang...but as folks mentioned, relying on the down-shift logic in auto mode where the Challenger driver knew what he/she was doing could easily explain a loss like this.
Old Apr 21, 2017 | 05:22 AM
SpectreH's Avatar
I always make sure to have some spirited acceleration every day so that the adaptive learning doesn't go all soft on me.
Old Apr 21, 2017 | 06:53 PM
TheReaper's Avatar
With Select Shift there's no reason to be in the wrong gear.
Old Apr 24, 2017 | 06:07 AM
