Fog lights on a base 2014
Old Oct 19, 2021 | 01:57 AM
AMADEOa7x's Avatar
Hi I just got a 2014 Mustang 🐎, base trim, it comes with fog lights, but I can't find where turn on the fog lights
Any ideas ?
Old Oct 19, 2021 | 03:44 AM
Siber Express's Avatar
Pull the light switch out when the lights are on.
Old Oct 19, 2021 | 06:36 AM
What he said and welcome!
Old Oct 19, 2021 | 07:19 PM
AMADEOa7x's Avatar
It feels like it's gonna rip apart
I cant pull the **** at all
Old Oct 20, 2021 | 03:37 AM
Does the Fog light switch looks like this?
The symbol on the left side lights up when the fogs are on and they do not work without the key on.
Old Oct 20, 2021 | 03:47 AM
AMADEOa7x's Avatar
All the same but without the pull word and the symbol but he does comes with the fog lights as in the pic from the post
I will need to upgrade the light switch **** right ?
Old Oct 20, 2021 | 05:00 AM
Unless there is another switch, some did not come with them and the previous owner might have added them. I know the harness was a little expensive so they might have gone a different route.
Old Oct 20, 2021 | 08:09 AM
AMADEOa7x's Avatar
I found a button tried use to see if works for the fog lights but I had no luck at all
I'm gonna take the car to my mechanic to find out if can use it or fix that button for the fogs also imma buy the upgrade for the switch lights
Do you believe it's better buy the switch directly from Ford or something like that?
thanks for the support
Old Oct 20, 2021 | 08:19 AM
SpectreH's Avatar
Depending on how the fog lamps were wired when added, swapping the factory switch may not gain you anything, other than a lighter wallet.
Old Oct 20, 2021 | 10:13 AM
The light switch is 30 bucks and it will give you auto lamps if the wiring is not there for the fogs.
That other pic was the wrong switch, the actual switch looks like this. Disregard the dust on it
You never can tell, light switch might have quit working and they replaced it with the wrong one.
Old Oct 20, 2021 | 11:00 AM
Bert's Avatar
are they aftermarket fogs or OEM?
I am guessing they are aftermarket, so you'll have to find the switch, wherever the prior owner installed it
Old Oct 25, 2021 | 03:26 PM
shaneyusa's Avatar
Yup this is what my '14 has in it. If it is different, they probably got the wrong one on replacement as stated. Or was this car V6 with a motor swap to a V8? Car looks like a GT/CS from where the fog lights are, or it could be a V6 with the Mustang Club package on it? Hard to tell from the OP picture if that is really a GT. Does the hood have vents?
I am guessing with the other mods, that the fog lights were added or moved on this car.
Old Oct 27, 2021 | 05:58 AM
vulrath's Avatar
The V6 performance package came with the GT/CS style fogs too. At least, I know for sure the 13 did, and there wasn't too much that changed from 13 to 14 in exterior appearance if memory serves.
​​​​​​If this was the case the switch would be the aforementioned special one, though.
My advice would be to go to a dealer and see if they can scan the VIN and get a spec sheet. Next step if that fails is to order that car's specific switch and see what features it has.
It is possible that the previous owner added an aftermarket kit and wasn't ever able to get it to work.
Old Oct 27, 2021 | 05:18 PM
That is just a Base V6, the Pony Package, Mustang Club of America and the base with the Technology package all came with the same Fogs as the CS/GT.
My V6, I put the California Special Grilles in after my MCoA lower grille was broke by a Rock and I could not get a new one. Fogs are Stock. Actually Ford got their head out of the Butt and made the Fog lights the same instead of 2 different ones in like the 2011-12 when the V6 cars had the non projector style fog lights and the California Special had the Projector style.
murdered14gt
'10-14 Exterior Modifications
19
May 8, 2015 12:04 PM
elkk
Dec 7, 2013 06:40 PM
ShaneGT
Feb 25, 2011 07:30 AM
MustangDan
18
Feb 10, 2005 03:48 PM
