engine code p0151 coming on...
Old 8/14/12 | 12:48 PM
Originally Posted by AlsCobra
Yes but is that bank 2? Paul! We need a ruling.
Did a quick scan through the manuals. Didn't find anything on bank definition. But they call the LH timing chain the one on the Driver's side, RH on the passenger side - as if you're sitting in the car. Reverse of firing order when you are facing the engine.
Old 8/14/12 | 01:38 PM
AlsCobra's Avatar
A Man Just Needs Some....
Lol. Pretty sure just searching that bank 1 on a Ford is passenger side. GM and dodge drivers side. Wonder why Ford didn't get bought out hmmmm?
Old 8/14/12 | 02:10 PM
holtywsp's Avatar
Everything back to stock now. Letting car idle for a few minutes to relearn idle and setting. Felt like it was trying to die but quickly picks back up to normal idle. I did a full system reset. Touched both battery cables together for 10sec before I reloaded the stock tune. Battery has been disconnected since 11am. I was always under the assumption bank 2 is drivers side. but I've also only driven fords.
Old 8/15/12 | 11:10 AM
Bucko's Avatar
Passenger side is bank 1 on the 5.0 (cylinders 1,2,3,4)
Old 8/15/12 | 11:20 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
BAM! called it
kylerohde
6/24/21 10:57 AM
STOERKEL
9/11/15 11:38 AM
cloyd65
7/30/15 08:48 AM
Will3212
7/16/15 10:30 AM
Quick Reply: engine code p0151 coming on...
