Dyno time and FRPP tune installed
Wow 395rwhp stock....something wrong there!! They should re calibrate their dyno or dynojet or whatever it is. When I got mine dyno'd the best it did stock was 372rwhp and that was the highest they have seen and they have done at least 20 2011 gt mustangs. And very bad numbers considering you probably got the 8rwhp from changing from 87 octane to 93. There is no way any 2011 gt makes 395rwhp stock with an axleback and 87 octane! Lol
Like Father...
I ♥ Sausage
I ♥ Sausage
Now if they weren't looking to see what the true gains were, just monitoring drivability, feel, etc. that's another story.
Read more, his car isn't stock.
That seems odd to me too. If you are trying to see what the real gain of a specific part is, you have to keep the parameters the same. It would be like running the car stock at a strip that's at 1500 ft. elevation, then adding a part, and running it again at sea level track.
This isn't the first time people have skewed test results like this.
At least they were upfront about it.
Numbers are obviously high for his mods, but who cares....it's just a dyno sheet. the real results will be from ET's and his real world driving experience.
As long as you like how it drives compared to before I could care less how much HP gans came from an FRPP tune and a drop in K&N.
Im really curious why you haven't installed the Steeda setup yet? Was this testing the reason?
I didn't put my Steeda setup on because I've been busy with work, and the parts are at powdercoat/paint right now. I also had issues with the tune they sent me, so that put me back a few days.
People run stock around 375rwhp - 380rwhp. That's legit.
Basically stock...but the X-pipe is ~10 hp. Please, read, comprehend, then post.
x pipe and axleback provide 10-15 rwhp.... Thats pretty accurate, and he stated they did 3 runs, from 390 to 395.
Ya the people that run on the same dyno that he did, the one that gives numbers way to high. Lol like I said I already dyno'd mine and the shop has seen at least 20 more and mine has a full catback system including an x pipe and running 93 octane and still only 375rwhp....so I know from real life experience that his numbers are off by quite a bit and the dyno they used is very generous! Where did you get your info?? YouTube and forums and Internet?? Lol
Also, read the settings that the dyno was exposed to, hence the bigger gains. Again, as said, read first than post.
Originally Posted by Daddyd666
Why would i read more? It has an x pipe an an axleback.....basically stock! And deffinitaly doesn't make 395rwhp with those mods! I would bet my 2011 gt on that! And I doubt it would make 395rwhp with those mods and the frpp tune and k&n drop in filter.
I'm being sarcastic. Dyno results are easily skewed. You can't cheat your way to a better ET, but I can cheat my way into a 500 rwhp dyno sheet.
See what I'm saying. If you are gonna bet your car, do it with odds in your favor. Bet it against ETs and not dyno numbers.
Either way 400 rwhp is awesome for a mainly stock GT. I love this **** car!
Originally Posted by S197 GT
I'll take that bet. I can make 500 rwhp on a mustang dyno with mine. I post a dyno sheet and you send me the pink slip?
Again mildly irrelevant, but they really need to recalibrate.
on a side note what is there to gain with the skip shift delete if you (aka ME) have the skipshift unplugged already ? Have you tried the car that way at all ?
thanks for your time to post up also how did you happen to be so dang lucky ?? hehe
#40
Originally Posted by Big Vito
