Dyno time and FRPP tune installed
I had the opportunity to take my car to Livernois today, and meet with a Ford Racing engineer to do some testing on their FRPP tune. This is the same tune that comes with their "Power Pack". I brought the car out, with a few gallons of 87 in the tank, and we set off.
To clarify, my car only has a Corsa X-pipe and axle back on it. The motor is stock.
First thing, we let the car cool to proper exhaust temps to get a correct baseline. The engineer wanted to make sure the exhaust temps for testing were identical before & after the tune. We did three runs with 87 in the tank, and my best run was 395rwhp/387rwtq. The first one was 391/382, and they went up from there. All pulls were done in 5th gear. Car has a 3.73 rear axle.
After a short cool down period, we loaded the tune and dropped in the K&N filter, in place of the standard one (the filter is included in the kit). At this time we also filled up with 93. After running a few more pulls with the upgrades, we had a best run of 403rwhp/393rwtq. What was most noticeable on the graphs was the smoothing of torque and the increase down low (graph coming soon!). The car had a consistent increase in hp/tq all across the rev range, and the rev limiter was shifted ~200 rpm higher than stock. The tune also eliminates skip shift (more on that in a minute).
After getting the car off the dyno and spending some time with it on the street, the car has totally changed. Throttle response is crisp and quick, and 2nd & 3rd gears pull great. You wouldn't think by driving/riding in it that the car *only* gained 10hp or so. Not having skip-shift waiting in the rungs definitely changes how the car shifts, especially into 2nd gear. Definitely a good thing there.
I spent some time talking with the engineer, and he had nothing but good things to say about the motor, the Boss 302, and the available FRPP parts. Some of the testing they've done on the supercharger kits without failure is pretty impressive.
To summarize, if you're looking for a safe, reliable, proven (and tested) tune, the FRPP kit should be considered. It takes a potent car and gives it a real nice kick of adrenaline in all the right places.
http://www.fordracingparts.com/parts...KeyField=12346
Dyno results (worst 87 to best 93 pull):
![](http://i177.photobucket.com/albums/w208/tunersteve/2011%20Mustang%20GT/dyno.jpg?t=1298638660)
Video link:
http://www.youtube.com/watch?v=YXOViUHKCBU
Video link:
I don't believe so. The goal of the FRPP tune is to upgrade something with a higher level of input than an aftermarket tune. We talked in depth about the extra hurdles that FRPP has to go through to market these types of products. They may not have the "highest" numbers, but they do go through the same certifications that the OEM tune/parts go through, so it's not as risky as some out there.
So basically you gained 8 peak rwhp. If you would have started with 93 you would have really found out the true increase of the tune. Overall it seems the gain was much smaller than its really worth because most run 93 in their cars. Besides the improved throttle response its very disappointing for the money it cost. Better to go with a mail order tune from the big boys.
so if the FRPP doesn't void warrenty....can't you technically buy another mail order tune...and if something goes wrong..have the FRPP tune handy and load that on that car? Im sure it doesn't remember anything other than the last thing put on there
Also the RWHP numbers seem drastically overstated. I haven't seen anywhere indicating that 5.0 is making 460+ at the crank?
But maybe I'm wrong?
Yeah, something doesn't seem right. 395rwhp WITHOUT a tune AND 87???
That's some crazy numbers. As Freakzoid mentioned, going from 87 to 93 alone would add 8rwhp. It wasn't done right.
I agree with redcandy. You didn't even gain 8 RWHP because that was 87 to 93. The 93 alone would have given you the 8 RWHP alone.
As I mentioned, we were all scratching our head. It did seem high. I highly doubt a Ford Racing engineer is going to "screw up" a tune. I also mentioned that the only power adder I have is the X-pipe, which Corsa claims will add around 10 hp.
He stated the car isn't stock..it has an X-pipe and axle backs. That alone clears up the mystery, as the X-pipe should be go for a solid 10-15 rwhp, with the axle backs adding just a bit (probably).
Heartthrob found something like 10 rwhp by slapping on muffler deletes, so we know there is power to be made there.
Also worth mentioning is that every dyno is a bit different. Temps were cold and dry today too. Only 35 deg. or so today.
This is the same dyno that Shaun (Stinger1982) ran his 430hp run on.
So the dyno reads high. The thing is it was done to show the gain of the tune even though the hp #'s may be a little inflated but it is still a paltry gain for a tune.
Yeah, I dealt with that issue on Monday.
IMO, running with 87 first, then running with 93 AND tune skewed the data. If you initially ran with 93, than did a run with tune and 93 as well, would seem more logical. No?
