Dual-zone AC performance
Hey y'all,
So I just took my 14 GT with electronics package on a road trip. To put it mildly, I don't understand how the dual zone climate works. My wife is always hot so she has the AC cranked on her side (60-65). No matter how I set my side, I would still freeze. If I set mine too high (like 90) it just shuts off the AC on both sides.
How's yours work? Is mine broken or are my expectations unreasonable?
Can't say for sure, but I would assume there is only so much deviation you can have between temps. You're basically asking for your wife's side to run off the A/C, and yours to run off the heat, which I doubt it can do. I think both temps need to be based on utilization of heat or A/C, and within so many degrees of each other at that.
I tried laserred's scenario (with the vents, pervs!) and the 60/70 was cold from both sides. 60/80 was warm/cold.
Anyone know more about how this works? Like where the temperature sensors are and what effect the outside or inside air have? Also, what does AUTO mode do, because even with it off the system attempts automatic climate control. Is it just the fan?
I tried laserred's scenario (with the vents, pervs!) and the 60/70 was cold from both sides. 60/80 was warm/cold. Anyone know more about how this works? Like where the temperature sensors are and what effect the outside or inside air have? Also, what does AUTO mode do, because even with it off the system attempts automatic climate control. Is it just the fan?
