Drag Racing an Auto Trans
For you seasoned drag strip drivers, what is your technique for competing in the 1/4 mile? What are your recommendations as to launch without damaging the engine/drivetrain? What RPMs do you use to launch and get the best time?
My personal experience was to brakestand in the warmup pit. I then did the same brakestand at the line, launching at about 4K RPM. She spun a bit on launch, but logged a 13.3 for my best time. This is when she was bone stock. Hoping my new setup gets me in the 12's.
How did you get 4K rpm on launch out of a stock automatic???
Probably going to get the quickest time by leaving at idle and rolling onto the throttle.
Click here to watch a vid of my friend, Rhonda, in her '11 5.0L automatic vs my supercharged '07 Mustang automatic. This vid shows how the burnout and staging should happen. Ignore my overly zealous burnout, though, and focus on Rhonda's '11 5.0L...
FYI, her '11 ran a 12.30 @ 113+ in this pass with just an SCT tuner, drag radials, 1-pc driveshaft, and axlebacks.
We were both on DOT drag radials, so our track is okay with us backing into the water. This track is Pacific Raceways (formerly known as Seattle International Raceways). At least they have us drive around the water box before backing up to burnout. Our other local track (Bremerton Raceway) makes everyone drive through the water before backing up, which IMO carries water up to the starting line from the front tires. Amazing how each track does things differently.
Assuming your automatic has the factory torque converter and you're running the factory tires, I would suggest that you pump up your front tires to 40-45 psi, drop your rear tires down to 20-25 psi. Heat up your back tires with a healthy burnout in the burnout box (with the brakes on to start, then let off to roll out of the water while still spinning the tires). Pull up to stage, but shallow stage (barely getting the second amber staging light to come on). Keep your foot on the brakes and hold about 1800-2000 rpm's to load the converter. On the last amber light, release the brakes and mash the gas to the floor. Don't lift off the gas until you're about 60' past the finish line. Check your timeslip and thank me later.
Don't go through the water box on street tires. just spin the rear tires quick to clean them. The more runs you make the better reaction time you get and taht will help your times and you will soon figure out the best way to launch.
A better reaction time doesn't lower your ET's. Reaction time is simply a measure of the time from when the green light comes on and you start moving. The actual timer for ET's doesn't start until you start moving. So, you could have a ten minute reaction time and still post a 12 second ET if you just stare at the green light for a long time before taking off.
Working on the launch - and subsequently lowering your 60' time - is a major factor in your ET, though. A good rule of thumb is that for every two tenths of a second you improve your 60' time, your 1/4 mile time should improve by three tenths.
Automatics like a good hit (flash) to launch harder, hence why you don't want to rev as high as you can against the brakes while waiting to launch. Keep the rpm's down around 2K max against the brake and simply leave a little sooner than you normally would (between the 2nd and 3rd amber, for example, instead of waiting for the 3rd amber) to give the transmission a little extra time to flash and hit harder on the launch to propel you out of the hole quicker.
