Drag Racing an Auto Trans
Old Jun 2, 2012 | 01:51 PM
brewsky54's Avatar
For you seasoned drag strip drivers, what is your technique for competing in the 1/4 mile? What are your recommendations as to launch without damaging the engine/drivetrain? What RPMs do you use to launch and get the best time?
My personal experience was to brakestand in the warmup pit. I then did the same brakestand at the line, launching at about 4K RPM. She spun a bit on launch, but logged a 13.3 for my best time. This is when she was bone stock. Hoping my new setup gets me in the 12's.
Old Jun 2, 2012 | 02:00 PM
BlackMamba03's Avatar
Bone stock runs in the 12's........
Old Jun 2, 2012 | 04:08 PM
Ltngdrvr's Avatar
How did you get 4K rpm on launch out of a stock automatic???
Probably going to get the quickest time by leaving at idle and rolling onto the throttle.
Old Jun 3, 2012 | 10:19 AM
Five Oh Brian's Avatar
Assuming your automatic has the factory torque converter and you're running the factory tires, I would suggest that you pump up your front tires to 40-45 psi, drop your rear tires down to 20-25 psi. Heat up your back tires with a healthy burnout in the burnout box (with the brakes on to start, then let off to roll out of the water while still spinning the tires). Pull up to stage, but shallow stage (barely getting the second amber staging light to come on). Keep your foot on the brakes and hold about 1800-2000 rpm's to load the converter. On the last amber light, release the brakes and mash the gas to the floor. Don't lift off the gas until you're about 60' past the finish line. Check your timeslip and thank me later.
Old Jun 3, 2012 | 09:15 PM
kn7671's Avatar
My Auto car ran a 12.80 @111mph on street tires, launching at about 1200 rpm's. Only mod was a Tune.
Old Jun 3, 2012 | 09:51 PM
Click here to watch a vid of my friend, Rhonda, in her '11 5.0L automatic vs my supercharged '07 Mustang automatic. This vid shows how the burnout and staging should happen. Ignore my overly zealous burnout, though, and focus on Rhonda's '11 5.0L...
FYI, her '11 ran a 12.30 @ 113+ in this pass with just an SCT tuner, drag radials, 1-pc driveshaft, and axlebacks.
Old Jun 3, 2012 | 11:40 PM
UnrealFord's Avatar
Jeesh who did the filming? About 1 minute late to see the time board. LoL
Old Jun 4, 2012 | 08:16 AM
Rhonda's husband, Dave, ran the camera. He's much better at racing - has an '03 Cobra that runs mid '11's and a '70 Mach 1 428 CJ that runs mid 12's.
Old Jun 4, 2012 | 07:00 PM
db2797's Avatar
Your track was ok going in the water with street tires? The track I go to has a freakn' cow if you touch the water with streets lol.
Old Jun 4, 2012 | 11:58 PM
We were both on DOT drag radials, so our track is okay with us backing into the water. This track is Pacific Raceways (formerly known as Seattle International Raceways). At least they have us drive around the water box before backing up to burnout. Our other local track (Bremerton Raceway) makes everyone drive through the water before backing up, which IMO carries water up to the starting line from the front tires. Amazing how each track does things differently.
Old Jun 5, 2012 | 02:56 PM
brewsky54's Avatar
Easy. Using my left foot, I mash the brake to floor. Then, with my right foot, push the gas pedal. Wait until the tach reads 4,000. Release brake.
Old Jun 5, 2012 | 03:01 PM
brewsky54's Avatar
Thanks Brian, this is exactly what I was looking for. Thank you in advance . I may not get to run her until September.
Old Jun 5, 2012 | 07:02 PM
db2797's Avatar
Are you serious that the other track makes everybody drive through the water? lol...agreed...it is so funny how every track is different. Yeah my track will only let non-DOT slicks in the water. But this track isn't the friendliest either unfortunately. I wish we had more tracks closer so I had better options.
Old Jun 5, 2012 | 07:33 PM
skunk21's Avatar
Don't go through the water box on street tires. just spin the rear tires quick to clean them. The more runs you make the better reaction time you get and taht will help your times and you will soon figure out the best way to launch.
Old Jun 5, 2012 | 10:53 PM
elvism's Avatar
I just power braked to about 1000rpm and took off
the traction control..ran 12.77 bone stock..
Old Jun 6, 2012 | 04:03 AM
kn7671's Avatar
How will lower reaction times improve your drag strip times?
Old Jun 6, 2012 | 04:42 AM
skunk21's Avatar
working on getting a better 60ft and reaction time is all good unless sitting at the light all day is fine. reacting to the lights quickly and getting a good launch a factor.
Old Jun 6, 2012 | 12:24 PM
A better reaction time doesn't lower your ET's. Reaction time is simply a measure of the time from when the green light comes on and you start moving. The actual timer for ET's doesn't start until you start moving. So, you could have a ten minute reaction time and still post a 12 second ET if you just stare at the green light for a long time before taking off.
Working on the launch - and subsequently lowering your 60' time - is a major factor in your ET, though. A good rule of thumb is that for every two tenths of a second you improve your 60' time, your 1/4 mile time should improve by three tenths.
Automatics like a good hit (flash) to launch harder, hence why you don't want to rev as high as you can against the brakes while waiting to launch. Keep the rpm's down around 2K max against the brake and simply leave a little sooner than you normally would (between the 2nd and 3rd amber, for example, instead of waiting for the 3rd amber) to give the transmission a little extra time to flash and hit harder on the launch to propel you out of the hole quicker.
Old Jun 6, 2012 | 01:04 PM
Ltngdrvr's Avatar
On a stock torque converter???
I don't think so.
Old Jun 6, 2012 | 03:05 PM
skunk21's Avatar
True it doesn't lower your e.t. and I messed up in my statement and meant work on your 60ft ( which is the advice I give all the time so go figure ) . If you are just running for times then yeah fine but if you are running in a bracket or just want to line up then your reaction time will matter.
muscle car fever
Oct 29, 2015 06:53 AM
samjluck
Sep 17, 2015 10:24 PM
Road_Runner
Sep 10, 2015 01:14 PM
Road_Runner
Sep 10, 2015 11:28 AM
Cdvision
Sep 5, 2015 05:22 PM
