Dot 3 or Dot 4 as the factory fill on Track Pack cars?
Old Nov 5, 2014 | 05:19 PM
John H's Avatar
I've done a couple searches and can't find the definitive answer, but does anyone know for sure whether Track Pack cars are filled with Dot 3 or Dot 4 brake fluid from the factory? I'm going to be a doing a hot lap event on Friday at VIR and it was suggested to flush the fluid for some Dot 4 before the event, just to be safe. But I couldn't help but wonder if Ford gave the Track Pack cars Dot 4 at the factory since it has other things like 5w-50 oil, low expansion brake lines, etc.
Old Nov 5, 2014 | 05:36 PM
kylerohde's Avatar
Haven't ever heard they get DOT4 so wouldn't count on it.
Old Nov 5, 2014 | 06:00 PM
dmichaels's Avatar
Factory filled with DOT 3 per my research. If you are running VIR do the flush. Do Motul RBF600. You'll want 3 bottles.
Old Nov 5, 2014 | 06:02 PM
dmichaels's Avatar
I suggest flushing the clutch too and abs if you can get out in some wet weather or on a dirt road! It's worth it to have brake peace of mind.
Old Nov 5, 2014 | 06:35 PM
John H's Avatar
Thanks for info. I've never done an event like this so I don't know how hard/fast we'll be driving. It's an event where you're lead by a pace car and there is no passing permitted, but I guess it's not unusual to get to 120-130 MPH depending on the pace car driver.
As far as the fluid you recommend, this event is Friday so I'd have to find the Dot 4 fluid locally. Is that Motul typically something you can get at a local parts store or does it have to be bought online?
Old Nov 5, 2014 | 06:42 PM
5.M0NSTER's Avatar
+1 with everyone else, and +1 to Motul RBF600. Good stuff. You definitely want DOT4 over DOT3 for track use.
Are you planning of using different pads? VIR is a fast track with huge brake zones... Fade will likely be an issues with stock Ferodo pads. The ~2 hours it takes to change front pads is possibly the best 2 hours of prep time you can do. Stock pads will fade at 800 degrees. Proper race pads will fade between 1650 and 2000 degrees.
EDIT: Sorry, just read the part about a pace car. You should be fine with the stock setup. I've done an event like that at Mid-Ohio once. It's more moderate use compared to a track weekend with point by or open passing. The pace drivers have to brake early.
Old Nov 5, 2014 | 06:53 PM
Brandon302's Avatar
+1 on better pads.
Old Nov 5, 2014 | 07:01 PM
John H's Avatar
They might not be high-end, but I do have Hawk Performance Ceramic front brake pads. Are these even a slight upgrade over the stock Brembo pads?
Old Nov 5, 2014 | 07:11 PM
5.M0NSTER's Avatar
They might not be high-end, but I do have Hawk Performance Ceramic front brake pads. Are these an upgrade over the stock Brembo pads?
Is it any of these?
http://www.hawkperformance.com/motorsports/compounds
If not then probably not. But again, with a pace car you should be alright.
Ecostang
Nov 3, 2022 08:50 PM
Bert
Jul 25, 2015 02:13 PM
MRGTX
Jul 21, 2015 02:08 PM
