Dent in drivers side MID pipe
Old May 18, 2013 | 07:58 PM
wentw1tj's Avatar
I was washing the car today and was spraying underneath it and noticed that my left side MID pipe has a about a 4 inch flattened dent in it? Has any one else noticed this on there cars. I will be taking it in the to the dealer because the dent will change the flow of the exhaust.
Old May 18, 2013 | 07:59 PM
JimmyM's Avatar
I have it too but apparently the crumple is normal.
Old May 18, 2013 | 08:09 PM
wentw1tj's Avatar
Ok that makes me feel so much better, thank you JimmyM, because if the car was run into something I don't know if that would have been all that was wrecked I might not of stumbled on the other pieces yet, until i was able to put it on a hoist.
Old May 18, 2013 | 08:13 PM
Gtstyles2's Avatar
Yea they all have this, mine has it as well
Old May 18, 2013 | 08:22 PM
Gabe's Avatar
Mine doesn't have it.
Anymore
Old May 18, 2013 | 08:35 PM
AzPete's Avatar
The other side is dented on the top.....mine are gone to.....
Old May 18, 2013 | 08:36 PM
bill0754's Avatar
Just had my first oil change, and the mechanic pointed out the dent and told me I must have bottomed out. Since I never did, I am glad I am not the only one with this dent.
Old May 18, 2013 | 08:59 PM
max5ive0's Avatar
This freaked me out once too.
Old May 18, 2013 | 09:50 PM
mrtnt3x's Avatar
I have it as well. One would think if you bottomed out that both would have dents?.?.?.
Old May 19, 2013 | 04:35 AM
Gabe's Avatar
There've been a few threads on this ... the resonators are the same on both sides, just upside down on one side. Ford says they needed the clearance against the fuel tank so they made it flatter like that.
If they installed both with the flattened part aiming up, none of us would probably ever know about this "dent"
Old May 19, 2013 | 04:37 AM
GreatOz's Avatar
Yep - mine too. Noticed the first time I had it up on jackstands, when my car had less than 100 miles on it. Seeing as how it's many of us, it must be happening as the car is coming off the assembly line.
Old May 19, 2013 | 05:40 AM
Gabe's Avatar
hUH? wHAT?
It's not a DENT, it's a FEATURE, at least according to Ford.
Read my post just above. It's done for clearance against the fuel tank
Old May 19, 2013 | 07:49 AM
BRADGTCS's Avatar
they do that to help reduce or eliminate exhaust drone.. That is why it is only on one side.
Old May 19, 2013 | 08:38 AM
Ajcruz1's Avatar
Is this normal for the V6s too, or is this only on the GTs?
Old May 19, 2013 | 09:43 AM
BlackedStang's Avatar
Yes, V6s too.
Old May 19, 2013 | 10:46 AM
Ajcruz1's Avatar
for those that got rid of it, how did you do it and did you notice any difference?
Edit: Nevermind, figured it out!
Old May 19, 2013 | 04:58 PM
AzPete's Avatar
Had a shop cut them out and installed a section of pipe. $80..... I have the gt 500 mufflers and it made them sound a bit meaner....louder.....and some pop when down shifting. A great sound made better.
Old May 20, 2013 | 10:28 AM
max5ive0's Avatar
I have a set of Dynomax Race Bullets with a 3" midpipe included, which just slips right on the H if you are interested. That way you don't have to worry about that flat spot anymore. Here is the sale:
https://themustangsource.com/f722/dy...leback-521807/
Old May 20, 2013 | 12:40 PM
dave07's Avatar
Haha, I saw the dent when I had the car on ramps. The car had about 500 miles at the time. I figured someone had bottomed it out getting off the shipping truck or something.
Very interesting...
Old May 23, 2013 | 04:18 PM
Gabe's Avatar
Again, both sides are the same part, they just install one upside-down for additional room next to the fuel tank
These are mine after they were cut out :
JonsMustang
Mar 5, 2016 05:44 PM
DrisStang
Sep 14, 2015 06:20 PM
devildog1679
'10-14 Interior and Audio
Sep 14, 2015 02:17 PM
Evil_Capri
Sep 11, 2015 08:39 AM
Sep 10, 2015 12:44 PM
