I'd think you'd be covered under the 5 yr 60k powertrain. But as you stated you're out of it now. That being said, at 61k, I'd think the dealership (depending) in good faith should still cover you. I know several folks who still have had something similar like this covered. But I'd get back to the dealership asap - before additional miles get added.
Doubt this falls under Powertrain, but agree that since you're so close, they're likely to help you out if you're a good customer.
That would be impossible, leaking from the tranny.
I tried to tighten the radiator drain plug and ended up sheering of the plastic nut part of the plug. I ordered a new radiator drain plug, engine sump drain plug, gr800 rotor and motorcraft coolant.
Depends if your car is an auto, if it is that's where the lines enter the cooler.
