Coolant leak
Old May 24, 2016 | 06:43 AM
trackpack13gt's Avatar
Coolant leak
I noticed my coolant level is 10mm below the cold fill line on the coolant tank.
It should not be looking coolant unless there is a leak.
While I was doing an oil change I looked around for leaking hoses but I could not spot any.
When I got on the ground and looked through the undergrad I spotted traces of coolant on the bottom of the radiator.
The car is out of the main warranty at 61k miles but does have the ford extended service plan basic. Does anyone know if I would be covered?
<br >
Old May 24, 2016 | 07:26 AM
JonsMustang's Avatar
Best bet is to check with the dealership.
<br >
Old May 24, 2016 | 08:31 AM
What's the "ford extended service plan basic"?
I'd think you'd be covered under the 5 yr 60k powertrain. But as you stated you're out of it now. That being said, at 61k, I'd think the dealership (depending) in good faith should still cover you. I know several folks who still have had something similar like this covered. But I'd get back to the dealership asap - before additional miles get added.
Old May 24, 2016 | 12:09 PM
kylerohde's Avatar
Doubt this falls under Powertrain, but agree that since you're so close, they're likely to help you out if you're a good customer.
Old May 25, 2016 | 04:31 AM
Blown CS's Avatar
Maybe it's just the picture, but that looks like tranny fluid.
Old May 25, 2016 | 10:53 AM
That would be impossible, leaking from the tranny.
I tried to tighten the radiator drain plug and ended up sheering of the plastic nut part of the plug. I ordered a new radiator drain plug, engine sump drain plug, gr800 rotor and motorcraft coolant.
Old May 25, 2016 | 11:39 AM
What would cause that leak, in general? Just seals wearing out? Hose coupler getting loose? Puncture in one of the hoses or reservoir? hmmmm
Old May 25, 2016 | 02:08 PM
Blown CS's Avatar
Depends if your car is an auto, if it is that's where the lines enter the cooler.
Old May 27, 2016 | 08:33 AM
No it is a stick. Still waiting for Levi town to ship the part.
smike308
Nov 10, 2016 03:43 AM
TMS Editor
Jun 2, 2016 04:11 PM
RMS70
May 13, 2016 06:35 PM
JeremyLee
West Coast
May 9, 2016 01:17 PM
Evil_Capri
Motorsports
May 2, 2016 12:36 PM
