Car's doing something weird, please read.
Old Nov 13, 2010 | 05:22 PM
alcarames's Avatar
Every now and then when I start the car it's as if the starter gets stuck and keeps on turning the motor but the car won't start. I have to take the key out and restart it for it to actually start. Then when it is running I can smell gas. My mods are steeda intake and tune combo. Anyone else experience this, could it be related to the tune? I still get the surge at idle where it goes down pretty low as if to stall. Any help would be greatly appreciated.
Old Nov 13, 2010 | 06:14 PM
MARZ's Avatar
Swamp Donkey Aficionado
Mine's done this twice, but the car started on both occasions. I'm not sure what's going on here.
Old Nov 13, 2010 | 06:28 PM
alcarames's Avatar
Do you have any mods?
Old Nov 13, 2010 | 06:51 PM
Ltngdrvr's Avatar
The car has auto start, and if it doesn't start right away it will keep turning.
The gas smell, does it happen every time or maybe right after you fill the tank?
Old Nov 13, 2010 | 06:56 PM
alcarames's Avatar
I notice the gas smell when the starter incident occurs. So the starter thing is normal?
Old Nov 13, 2010 | 07:08 PM
eliyarbrough's Avatar
Mine has done this twice. 1st right after I removed the positive battery cable, so I thought that was OK. It did it last night, just like 2 seconds. All I have done to mine is add the Flows. Kinda forgot about it til I read this.
Old Nov 13, 2010 | 07:29 PM
Fire512's Avatar
I haven't heard about a gas smell but the starter issue is well documented. https://themustangsource.com/f726/st...-issue-485021/
Old Nov 13, 2010 | 07:55 PM
Knight's Avatar
Needs to be more Astony
You need three things to start a car, air, gas and spark. Gas smell is because of raw gas being sent through the valves when it didn't start, no biggie. It will just burn off or evaporate once the car gets going but you will get that smell a bit.
Old Nov 13, 2010 | 08:02 PM
assasinator's Avatar
mine has done it twice. 1st time it started after i tried it the second time. the 2nd time i had to try it three time. the third try i gave it gas and it started.
Old Nov 13, 2010 | 08:42 PM
montreal ponies's Avatar
Maybe you got a carburated pushrod 5.0 instead. Just sayin'. To OP, before starting the car, are you giving it any gas at all !
Old Nov 13, 2010 | 09:56 PM
Lancel's Avatar
I suspect this is the known and relatively common issue affecting most of the early 5.0s. It happens to a lot of us, and it's not mods, as mine is completely stock (including tune) and it does this once in a blue moon, although I haven't noticed a gas smell. Some people they have to take the key out and try to start again, others it will start itself after a few seconds of letting it turn over. For everyone though it only happens once or twice. I use mine as a daily driver and have probably started it 300 times, it has only "stuck" around 5 times total. Not sure on what conditions cause it but have been a few theories like the engine being flooded with gas.
If it's that it's not going to be an issue, it's been known since like July, and no one's engine has exploded or anything. But that's assuming it's this issue of course, but it does sound like it. If it happens perpetually though then it's something else.
Old Nov 14, 2010 | 10:02 AM
alcarames's Avatar
Ok, that's good its not just something weird only my car is doing. I guess I missed the sticky starter issue thread. Thanks for the help folks.
Old Nov 14, 2010 | 03:55 PM
vdub2stang's Avatar
I've had this issue a few times myself. I have noticed that it only happens WHEN I use the auto-start. If I hold the key cranked until I hear it finally start then it NEVER happens. Auto-start seems to be the issue.
Old Nov 14, 2010 | 04:22 PM
Jcint's Avatar
I hope there is a TSB on this soon. It's happened to me at least 4 or 5x so far. Kinda embarrasing having a new car stall on you.
jc46002003
Apr 15, 2016 03:00 PM
f1-cobra
Aug 1, 2015 08:02 PM
roushcollection
Jul 28, 2015 02:08 PM
MicroSprint5
Jul 15, 2015 11:03 PM
whowasthat
Jul 11, 2015 03:49 PM
