Buzz from instrument cluster
Old Dec 8, 2014 | 09:47 PM
DrDisney's Avatar
I am getting a buzzing sound from the silver circle encasement around the speedometer. Anyone else experience this? Solutions? Thanks
Old Dec 9, 2014 | 03:31 AM
MJJ's Avatar
MJJ
some black electrical tape wrapped around the gauge usually will reduce/eliminate the noise. Obviously the dash/cluster need to be pulled to get at it.
Old Dec 9, 2014 | 09:58 AM
FordService's Avatar
Hey DrDisney,
It’s been a while! Have you addressed this with your Ford Dealer yet?
Deysha
Old Dec 9, 2014 | 10:53 AM
lakersfreak's Avatar
I also hear a buzzing sound somewhere from dash near passenger side (or at least it sounds like its coming from there) every time I go over a crack in the pavement. It's super annoying.
Old Dec 9, 2014 | 11:54 AM
magnido45's Avatar
For a temp solution, pull on the loose cluster ring slightly toward you with your thumb and index finger and the loose clips from behind the ring will "lock" against the cluster housing...it will eventually get loose again.
But here is a permanent fix...download the pdf:
http://www.allfordmustangs.com/forum...tle-fixed.html
Old Dec 10, 2014 | 09:51 AM
Magnido45 has some great information, lakersfreak. You should address this rattle with your Ford Dealer first, and let me know what they say.
Deysha
Old Dec 14, 2014 | 10:32 PM
DrDisney's Avatar
Thanks everyone. Tha PDF probably is the path to the solution.
Old Dec 21, 2014 | 09:00 PM
DrDisney's Avatar
Magnido45, thanks for that detailed solution! I think I'm going to get that done.
Old Dec 22, 2014 | 09:18 AM
magnido45's Avatar
Let us know how it went if you try the fix yourself...
Caution...I tried messing around with my cluster a while back and it was easy to pull out...but it was a pain to put back in because the steering wheel was in the way...you have to get it in at a specific angle to push it back in...but it's do-able...
Old Dec 22, 2014 | 09:20 AM
magnido45's Avatar
I get this at times too...still can't figure out where it's coming from unless you have a passenger sit and stick their ear towards the buzzing sound while you're driving...
Old Dec 22, 2014 | 08:10 PM
3point7's Avatar
I get a fast passed rattle from the chrome ring around my driver side AC vent when the car is cold inside. My guess is the ring contracts when its cold and leaves just enough of a gap to rattle against the housing. It goes away as the car warms up. Eventually I'll get tired of it, pull the ring out and put something behind it to keep it from rattling. We have to keep in mind that Ford does everything they can to build these cars with an eye towards cost reduction. It doesn't bother me though because the basic construction of the car is solid and with a little effort you can easily make the car better and more refined in almost every respect. So while a company like BMW or Lexus might engineer their interior components to never rattle by way of cushioning or backing I keep in mind that those cars also cost a fortune. To get even V6 level of performance at Lexus you have to spend 50 grand or so. To get Mustang GT performance you're in the 60 to 70 grand range. So I don't mind having to tinker with a few interior components here and there to keep the rattles and knocks from taking place. It's part of owning a car like the Mustang. If I wanted a mind numbingly boring car that I never interacted with I'd buy a Lexus.
Old Dec 22, 2014 | 08:24 PM
PonyMuscletang13's Avatar
I had a buzzing noise sounded like coming somewhere from the instrument/dash area but turned out to be the rearview mirror. Try holding the mirror and see if buzzing goes away. Replaced mine under warranty.
Old Dec 22, 2014 | 11:34 PM
PJRManagement's Avatar
Currently a Corvette Owner!
All of the chrome dash surrounds in the 2010-2014 have no real absorption material. I took some foam, and, using a very small flat-head screwdriver, wedged the foam along the outside of each chrome surround. Fixed most of the rattles - permanently. If it's the rear-view mirror, or inside the instrument panel, then a real repair is needed.
Old Dec 26, 2014 | 08:17 AM
DrDisney's Avatar
PJRManagement, can you give more detail on what you did? Did you pull out the cluster or was this somehow done with the instrument cluster still in place?
tukatz
Off-Topic Chatter
23
Oct 20, 2015 09:54 AM
JonathonK
Sep 24, 2015 06:31 PM
samjluck
Sep 17, 2015 10:24 PM
Grabber5.00
Sep 13, 2015 06:53 AM
