Broken transmission crossmember
Old Aug 6, 2023 | 05:44 PM
Black Fire's Avatar
Haven't been on here in a minute (forever)
Asking if anyone has come across a crossmember that has broken like this before
I don't need to know why it happened because well it is what it is.
Just curious if it's been seen before.
Old Aug 6, 2023 | 06:36 PM
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
I'm old, eyes going bad, and on a phone, you'll have to point me to what is broke.
Old Aug 6, 2023 | 07:08 PM
Siber Express's Avatar
I would be looking at the Motor mounts at the same time with that broke like that
Mount took the whole piece out Lee, the other side is cracked around the mount stud also
Old Aug 6, 2023 | 07:32 PM
Like Father...
I ♥ Sausage
Thanks Ken, I see it now. I agree with a motor mount, should not be that much twist there to do that. Unless maybe really high hp launching on slicks, and that's a stretch unless something else let go too.
Old Aug 7, 2023 | 06:35 AM
Looks like one of thos e high quaility parts from china
Old Aug 7, 2023 | 08:36 AM
Black Fire's Avatar
Car is a 160k mile daily driver, been to the track once with maybe 3 passes on it.
It's never launched hard because it's a daily, also still has the original clutch.
There are signs of corrosion in the few pieces that I managed to pull out. Water probably sits in the channel the trans mount is bolted to because there's no drain holes. Thinking it was only a matter of time before it weakened enough to break.
Old Aug 7, 2023 | 08:49 AM
dusman59's Avatar
Make sure motor mounts are good. Excessive motor twisting over time could cause stress on those trans mounting points.
Old Aug 7, 2023 | 10:30 AM
shaneyusa's Avatar
Wow that is a nasty bolt hole blow-out. The other one is on it way to the same. I have not seen anything like it. Almost looks like bigger road debris may have hit it a some point. Or just cheap Chinese pot metal under stress.
Old Jun 11, 2024 | 02:30 PM
Gregduster's Avatar
I had the same issue
2012 mustang V6 manual transmission - started hearing a horrible metal on metal screech - it was the transmission crossmember. It just fell apart around the bolt holes. Parts and labor 240$ and back on the road. Good for another 100k miles
Old Jun 11, 2024 | 03:31 PM
05stangkc's Avatar
Welcome!
Thanks For Sharing! Does Not Appear Ford Made Those To a Very Stout Spec! Good Thing to Keep an Eye out For!
KC
Old Jul 4, 2024 | 04:18 PM
Franck87's Avatar
Bonjour, je rencontre le même problème que vous sur un V6 3.7 de 2011.pourriez vous me préciser votre motorisation car sur ma traverse il y a aucune référence et je pourrais me servir des vôtres. Je suis en France et pour l'instant je ne trouve pas la pièce.je suis désespéré.
Old Jul 4, 2024 | 04:33 PM
05stangkc's Avatar
@Franck87
Hello, I am having the same problem as you on a 2011 V6 3.7. Could you tell me your engine because on my crossbar there is no reference and I could use yours. I'm in France and for the moment I can't find the part. I'm desperate.
https://www.ebay.com/itm/22615131990...Bk9SR7yShP6PZA
EBAY USA
Bon Chance! 3.7L Application
KC
https://www.fordpartsgiant.com/parts...html?pnc=6A023
Different Part Numbers By Engine Size.
https://www.ebay.fr/sch/i.html?_from...023-A&_sacat=0
Ebay France
Old Jul 4, 2024 | 04:47 PM
Franck87's Avatar
@Franck87
EBAY USA
KC
Ebay France
Merci de votre réponse rapide,j'ai juste oublié de préciser que c'était une boîte manuelle.merci encore.
Old Jul 4, 2024 | 05:09 PM
05stangkc's Avatar
You are welcome!
36 / 5,000
Je vous en prie!
Kc
Old Aug 30, 2024 | 12:12 PM
KonaMustangGT's Avatar
Yes, I had this too. It didn't break through before I caught it, but it looked to me like galvanic corrosion. The crossmember is aluminum, but the bottom part of the isolator that bolts to the back of the transmission is steel. Water / salty road spray works its way in between the two and starts expanding, building pressure and pulling the isolator stud/nut through the crossmember. Mine had lots of white crud built up between the two. I even put a straight edge on the bottom of the old isolator, it was bowed in.
I replaced the isolator as well and sprayed a thin amount of rubber undercoating under the isolator in the hopes it would delay the next round of corrosion.
Old Aug 30, 2024 | 12:14 PM
05stangkc's Avatar
Thanks For The Tip! Sounds Like a Plan!
KC
Moustang
Motorsports
25
Mar 15, 2014 12:19 PM
tukatz
22
Sep 11, 2013 07:35 PM
black_bullitt
2012-2013 BOSS 302
101
Oct 23, 2011 02:50 PM
Zastava_101
Oct 6, 2011 03:41 PM
