Brake part number request
Old 1/29/19 | 04:42 PM
Hwyman's Avatar
Hey everyone. I am doing the GT500 rear brake upgrade and I cannot find the part number for the bolts and nuts for the rear adapter plate
Can anyone help me out. Yes, I googled it but I was unable to find it.
There are 4 of them.
Old 1/29/19 | 06:54 PM
EF1's Avatar
EF1
The part number is 1R4Z-2321-BA. When I did the conversion a couple years ago the part was not available from Ford. I reused the factory bolts with some loc tite to make sure they didn't come loose.
Old 1/29/19 | 07:09 PM
Hwyman's Avatar
Thanks man. I appreciate it.
Since you used the original bolts with loc tite I'll go that route. I only have 29k kms so the bolts are practically new still
Old 1/29/19 | 08:43 PM
EF1's Avatar
EF1
Like you I wanted to use new bolts, since Ford recommended it. I ordered the parts and they were back ordered. Then the order was cancelled and my money refunded due to Ford no longer making the item available. I wouldn't worry about using the factory bolts with loc tite, just torque them properly. Mine have been on the car without issue for a little over 3 years and I track the car.
Old 1/29/19 | 11:49 PM
Hwyman's Avatar
Thats what I needed to hear. I could not figure out why they recommended they be replaced. I'm pretty sure the specs on those bolts are made for a decent amount of force. I would only be concerned if they were corroded.
Old 1/30/19 | 06:25 AM
Bert's Avatar
simpler solution, is use these:
https://www.ebay.com/itm/05-14-Musta...TPnF:rk:1:pf:0
Old 1/30/19 | 08:30 AM
Hwyman's Avatar
Yah, I have seen those, but I wanted to go the route of doing the proper setup.
Thanks for the info though.
Old 1/30/19 | 09:30 AM
Bert's Avatar
up to you, it's your time and money . . . speaking for myself, I saw no benefit to offset the added cost and time needed for the "proper setup" . . . and I know of at least two people who have used those brackets, and pushed their cars harder on the road track (with slicks and brake cooling ducts) than I probably ever will, so not worried about any failures
Old 1/30/19 | 06:31 PM
EF1's Avatar
EF1
It is two different ways to achieve the same result, larger rotors on the rear. People have had good luck with both set ups. I have seen both used at the track with good results. I chose to go the Ford route because I wanted it to look like it came that way and wasn't an afterthought. It does cost a little more and take a little more time to use the GT 500 parts, but I needed to change the gear oil in the rear anyway. I also took the opportunity to put new clutches in the trac lok and upgrade to a finned aluminum diff cover with fill and drain plugs to facilitate fluid changes in the future. Even with the extra maintenance that I did it only took an afternoon to complete.
Old 2/5/19 | 08:08 PM
shaneyusa's Avatar
Here is the part list from when I did my upgrade about 18 months ago. This is all the needed parts if you put in all new. Love the upgrade. Looks great and have not had a single complaint. Do it!
FYI here is a thread on this very topic from a while back that should give you all the info you need to make it happen.
https://themustangsource.com/forums/...pgrade-542581/
Jw233233
2/20/19 04:46 AM
