Bought a built Tr6060,MGW Shifter and clutch for my 12 5.0!
Old Jul 19, 2011 | 07:28 PM
  #141
bob's Avatar
bob
Originally Posted by ShaneGT
correct, VVT is not functioning, the reason you get power above 4k is where the cams are designed to get power, below that they rely on the VVT to make power. I would check and make sure all the plugs are pluged in and ground wires(if the have any) are properly grounded.. The shop that did the install should have done all of this if they were any good..
Well that answers a suspicion I had about TiVCT - I thought due to the RPM limitations of the system, Ford would use a counter intuitive strategy advancing the cams rather than using the system to retard the cams at high RPM.
Old Jul 20, 2011 | 06:03 AM
  #142
ShaneGT's Avatar
correct, TiVCT is basically disabled at WOT and high rpms, using the cam profile fully..
Old Jul 21, 2011 | 06:24 PM
  #143
unas2k5's Avatar
Thanks everyone for your help. You guys are awesome!
Took it in to the Ford dealer. It was a mini 15 Amp fuse for the Hego sensors! Everything is looking fine now! I put 30 miles on her and no more check engine light.
They charged me $150. All they noticed was the exhaust LMAO. I'm going back to that dealer
Old Jul 21, 2011 | 06:33 PM
  #144
way2qk4u2c's Avatar
That's awesome man. Glad it's fixed. One sweet setup you have very unique.
Old Jul 22, 2011 | 01:05 AM
  #145
unas2k5's Avatar
Thanks!
Old Jul 22, 2011 | 03:12 AM
  #146
unas2k5's Avatar
Putting in 4.30's!
I heard 4.30 gears whine , how bad? Thanks!
Old Jul 22, 2011 | 06:06 AM
  #147
ShaneGT's Avatar
great to hear that its all working.. yea a burnt fuse would cause all of them to stop working.. didnt even cross my mind >.<
Old Jul 22, 2011 | 07:29 AM
  #148
Fat Boss's Avatar
Am I missing something? They charged you $150 to replace a 15 amp fuse? And you're going back? I hope you're joking...
Old Jul 22, 2011 | 08:25 AM
  #149
newpony's Avatar
I'm pretty sure they are charging him for time expend troubleshooting the problem not the actual fuse.
Old Jul 22, 2011 | 09:58 AM
  #150
ShaneGT's Avatar
at 75 to 100 bucks an hour.. not bad. prolly charged him 1.5 hours diag charge.. may be a cheap fuse, but doesnt mean it is easy to find that is the problem..
Old Jul 22, 2011 | 12:34 PM
  #151
unas2k5's Avatar
Lol, it was a $140 fee to just plug in their check engine diagnostic tool. The fuse costs $4.
They said the warranty would've covered it but the wiring under the car wasn't at factory location so they knew the wiring was messes with and that could've caused the fuse to blow. They also added that when my exhaust was installed they must've moved the wiring around and it caused the fuse to blow.
They also noted " exhaust completely modified". LMAO they didn't even notice the transmission,clutch,driveshaft, or short throw LCA's and tune.
Service advisor was very cool. " what did you do to this thing??"
Old Jul 22, 2011 | 01:16 PM
  #152
Fat Boss's Avatar
OK. Then the lesson learned is if you have ANY electrical problems you check your fuses first. Glad you got it worked out. Let us know how the gear ratios affect the driving!
Old Jul 22, 2011 | 03:37 PM
  #153
unas2k5's Avatar
I definitely will! Then the track!
Thanks!
Old Jul 22, 2011 | 03:50 PM
  #154
Ltngdrvr's Avatar
Only whine if they were not machined correctly or not installed correctly.
Old Jul 22, 2011 | 04:13 PM
  #155
unas2k5's Avatar
Ok cool. So I should expect it to be as silent as my stock 3.73's.
I can't even do a 40 roll unless I'm in 1st gear. The car really needs that 4.30 gear. This would help with low end acceleration and not affect top end? Will I be able to go over 160 with this gear?
Thank you.
Old Jul 22, 2011 | 04:44 PM
  #156
Ltngdrvr's Avatar
Your top speed will be drag limited way before you run out of gear.
Old Jul 22, 2011 | 06:13 PM
  #157
unas2k5's Avatar
Cool! Thank you sir.
Old Jul 22, 2011 | 11:58 PM
  #158
unas2k5's Avatar
Saleeeeeeeeeennnn
Old Jul 23, 2011 | 12:11 AM
  #159
unas2k5's Avatar
Just some pics.
Old Jul 23, 2011 | 12:33 AM
  #160
unas2k5's Avatar
At the track.
A guy with a new grand sport is afraid to race me. Lol.
He wants two and the leave! I'll let you guys know how it goes.
