Borla exhaust installation question
Old Nov 13, 2011 | 10:06 AM
romendo's Avatar
So I wanted to install my Borla exhaust. The stock mufflers came off fairly easily. However, installing the Borla exhaust poses a problem. I can't get the back hanger into the rubber grommet. The tip is pointed downward (away from the grommet), which makes it impossible to get into the grommet.
I tried to get the whole rubber grommet off - no success. Any tips?
Old Nov 13, 2011 | 10:27 AM
Overboost's Avatar
Did you loosen the panhard bar brace on the one side? That makes things a lot easier.
Old Nov 13, 2011 | 10:29 AM
jacostang's Avatar
Sorry man, I used the Roush and they went right on.. Is something bent on the Borla's?
Old Nov 13, 2011 | 10:40 AM
romendo's Avatar
Getting the exhaust on was not really a problem. Where I was stuck was getting the back hanger into the rear grommet. Not wasting any more time I just removed the whole hanger, pulled off the rubber grommet, put the hanger back on, and then put the rubber grommet on the muffler hanger first and then onto the hanger on the car. Now I just need to get it all the way back onto the car. These rubber grommet are such a pain in the butt.
Old Nov 13, 2011 | 12:23 PM
Thomas S's Avatar
I had to unbolt the hangers to get mine on.
Old Nov 13, 2011 | 12:39 PM
Overboost's Avatar
Do you mean rear as in tip side or clamp side? If it's the tip side grommet, just spray some WD-40 on the exhaust hanger, and it should slide in. I hung mine first, then oriented the pipe and secured the clamp. It's been fine since.
Old Nov 13, 2011 | 01:08 PM
romendo's Avatar
Thanks for your help. In hindsight I think it is impossible to get the rear hanger (closest to the tips) into the rubber grommets without taking off the whole rubber grommet or the whole hanger that is mounted to the body.
I finally got it all done. Let's hope it all stays connected...
Old Nov 13, 2011 | 02:02 PM
Overboost's Avatar
You don't need to unbolt it to get it there. Hang that one first, then slide the two forward hangers in position, then attach the clamp.
Old Nov 13, 2011 | 02:20 PM
romendo's Avatar
That might have worked. I wasn't sure if it would travel enough in order to slide in the two forward hangers.
apial
Sep 6, 2015 10:40 AM
Good Times
Aug 29, 2015 10:18 AM
tony2014mustang
Aug 9, 2015 03:04 PM
