Blind Spot Mirror....What am I doing wrong?
Old 7/21/10 | 09:39 PM
RedWings's Avatar
I have my mirrors set like always and I don't see how these blind spot mirrors are supposed to work. Everything I see in them are way outside of where my blindspot is.
Someone school me on this.
Old 7/21/10 | 09:50 PM
Jott's Avatar
It works. Pull over on a quiet street and put a parked car in your blindspot, then have a look, it'll definitely be there.
Old 7/21/10 | 10:05 PM
RandyW's Avatar
I've got my main mirrors so they are showing a little bit of rear fender in each, so I can place it for parking. The blind spot mirrors show me what would normally be in the blind spots.
Old 7/21/10 | 11:05 PM
druice's Avatar
Oddly enough my mirrors were already perfectly set the first time I took my car for a spin. I'm loving them, and it boggles my mind why these aren't a standard on all modern cars. The blindspot mirror does give you a wider angle than just the blind spot, and I can actually see about two lanes worth beside me. Once you get used to them you'll appreciate them a lot more.
Old 7/22/10 | 10:10 AM
hawkeye18's Avatar
I've had those little 1.5" stick-on "dot" mirrors on my SHO for a long time, and they might look a little cheesy, but they really do work. When glancing over at my driver's side mirror, with the mirror in enough that I can see the side of the car, the dot mirror completely gaps (and overlaps) the area between the outer edge of my normal mirror and my peripheral vision.
This means as a car overtakes me on the left, I can see it in my mirror, the mirror/dot mirror, then dot mirror, then dot mirror/eyesight, then it's basically in front of me already. I have 0 blind spot, and the 15" rear view mirror helps things out a lot as well! I never have to look behind me or over my shoulder to do lane changes which is a lot safer, because time spent looking behind you is time spent not looking in front of you.
I haven't had a chance to drive the '11 yet (or even see it in person ) but I would imagine those mirrors would accomplish basically the same thing. Yeah, it's a little weird to get used to, but they work oh so well.
Old 7/22/10 | 10:23 AM
whysoserious's Avatar
I think it's cool that these new models have these integrated mirrors, however I'm curious as to whether they are even really necessary. I have used the technique below for setting mirrors ever since I started driving as a teen, and I've never had a problem with blind spots. Just my take.
http://cartalk.com/content/features/...alkMirrors.pdf
Old 7/22/10 | 11:20 AM
1chocophile's Avatar
+1
This technique works well.
Old 7/22/10 | 11:27 AM
JScottGT's Avatar
I have used this method for years and it eliminates the "blind spot." There is no reason to be setting your mirrors so you see your car. It will always be there, now the poeple driving next to you will not be. The spotter mirrors are there for people that set up their mirrors to see their car. If you set up your mirrors like described in the link, they may not necessarily work for you.
Old 7/22/10 | 11:38 AM
RedWings's Avatar
I'm going to try this out
Old 7/22/10 | 01:13 PM
OAC_Sparky's Avatar
To each their own. Personally, I set my mirror so it just "barely" sees the side of the car, and I recommend anyone that regularly parks in large lots to do the same. It just acts as a "double check" that your mirrors are set properly.
Too many times I've returned to a parking lot to discover that someone "bumped" the mirror knocking it out of line and looking outwards instead of behind you, missing the blind spot completely. At night this can be very dangerous if you don't realize it before entering a highway. Even when the mirror just barely catches the side you can still usually see a lane and a half beside you,
Old 7/22/10 | 01:17 PM
codeman94's Avatar
can someone post a pic of the view from these mirrors?
trackpack13gt
7/25/17 06:29 PM
ricky1728
2/11/16 08:25 PM
PonyMuscletang13
9/29/15 10:40 AM
oldnjguy
9/10/15 03:39 PM
