BAD blue oil smoke after a hard run
Old Oct 12, 2011 | 06:33 AM
assasinator's Avatar
well, i have severe oil smoke when i lift after running it through the gears. i dont shift it above 7k. it smokes from both tailpipes when i first lift, then settles to the passenger pipe, and after every downshift it smokes severely.
IT IS OIL SMOKE. save all of the BS. i dont know if its oil accumulating in the manifold that gets picked up under high vacuum conditions, or something worse.
it does not smoke under acceleration. just when i downshift.
i am going to buy a few pistons, rings and head gasket to prepare. plugs look normal last time i looked. datalogged a/f is fine. the tune has 2 degrees pulled globally.
edited out. i guess i do need to lighten up.
Old Oct 12, 2011 | 07:23 AM
alcarames's Avatar
Any check engine lights? I think all of the guys with blown #8's had a misfire code. Well... good luck either way. What tune are you running?
Old Oct 12, 2011 | 07:27 AM
VTXFrank's Avatar
anyone who wants to call me a liar or some names can meet me here in tn for what i will give you. :PM me and ill handle you.
Wow, threatening people turn your ***** red or what?
And why in the WORLD would you pull two degrees globally? Do you know what that does? It doesn't just affect the WOT settings ya know.
Sometimes, I think you have more testosterone than brains.
Old Oct 12, 2011 | 08:22 AM
blackgt87's Avatar
Lol I like how you're ready to beat up the whole internet because your car smokes.
Do you happen to have a cammed idle tune?
You sure its oil smoke? I think you're probably a liar...
Old Oct 12, 2011 | 08:29 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Old Oct 12, 2011 | 08:33 AM
AlsCobra's Avatar
A Man Just Needs Some....
Op. Check your throttle body and see if oil is present there. Could be coming from pcv tube going to your air intake. And lighten up. Shyte happens when you run these cars.
Old Oct 12, 2011 | 10:33 AM
LEwis26's Avatar
Are you running an oil separator?
Old Oct 12, 2011 | 10:35 AM
im not running a seperator. i guess i need one. ill look at the throttle body today.
Old Oct 12, 2011 | 10:52 AM
blackgt87's Avatar
I would take a look at the PCV valve too, I have been told that even when brand new they don't work like they should, and some are much worse than others.
Old Oct 12, 2011 | 11:22 AM
Back in the day, oil smoke on lift off/decel was valve seals. So that points to the PCV tube. Is the 5.0 an open tube like the 4.6? No actual valve?
I agree with the oil sep.
Old Oct 12, 2011 | 12:09 PM
Flagstang's Avatar
Spam Connoisseur
I got هَبوب‎ed
Old Oct 12, 2011 | 12:21 PM
blackgt87's Avatar
what are you the shoe police now?
Old Oct 12, 2011 | 12:25 PM
Bush dodges shoe.
Jim74656
May 1, 2023 02:15 AM
Ecostang
Nov 3, 2022 08:50 PM
jc46002003
Apr 15, 2016 03:00 PM
RedCandy5.0
Oct 4, 2015 06:51 AM
Mackitude
Aug 13, 2015 01:05 PM
