Axleback install - break a weld?
Old Feb 28, 2011 | 02:42 PM
SurfnSoCal's Avatar
I searched but couldn't find any threads re: this. Apologies if this has been answered before.
I just received my Bassani AB and the instructions state you have to break the stock weld on the clamps to remove the stock mufflers. I don't remember having to do this on my 05, but that was about 6 years ago.
Is this true? Hard to do?
Old Feb 28, 2011 | 02:51 PM
S197 GT's Avatar
3rd Times A Charm
The clamp that goes onto the over axle pipe from the muffler has a spot weld.
Remove the exhaust, it's a little bit different than the '05, but basically the same.
Pull the axleback off, and you'll see that the clamp has been tack welded on.
I bent it back and forth until it broke free.
It's really simple.
I was still able to do the complete install from off of my back without the use of a jack or jackstands.
I'm 260, 6'3", so just about anyone can do this as well off of their back.
jokerstars's Avatar
Yeah I just got off the phone with a mechanic who wanted to know about that so he could give me a quote.
Everywhere I've read says installed ABs are easy and you don't even need to jack up the car. But if the stock exhaust is required to be cut out...
Yeah, I need answers on this too.
edit: Uh, is there welding involved?
Old Feb 28, 2011 | 02:53 PM
LEwis26's Avatar
Joker, it's not required to be cut out or welded in. There's a small weld to break, and then the new ones just clamp on. You could do it in a parking lot with some simple hand tools.
Dont you have a friend you could borrow a driveway from for an hour?
Old Feb 28, 2011 | 06:33 PM
mystickeith50's Avatar
With the bassani axle back do u have to re use the stock clamp, or does it come with a new one?
Old Feb 28, 2011 | 10:47 PM
Jcint's Avatar
I just installed borla Atak axel backs and it's not hard at all. The only weld you will break is on the clamps so you can re-use them.
Old Mar 1, 2011 | 10:25 AM
Modshack's Avatar
And the clamp comes off with the Muffler, so this is done off the car. Only Takes a minute to break the spotweld..Not a big deal.
Hristofor
1994-2004 V-6
Sep 11, 2015 12:05 PM
Sep 10, 2015 12:44 PM
SMOKE46
Sep 6, 2015 09:40 PM
Cdvision
Sep 5, 2015 05:22 PM
