Axle 3.55 to 3.73 Worth it?
With the transmission in the 2011 GT and 3.55s, your first gear will be like a 2010 Gt with 3.73s. And your 6th Gear would be like the same with a 3.31. Given the extra HP and Torque of the new 5.0, unless you planning on drag racing it, go with the 3.55s. It is a 7% change from the 3.31s. Making the jump from 3.31 to 3.73s is close to a 12.5% change.
gear change
I dont want to be argumentative but, there is no way to lose 3 tenths by switching from 3.55 to 3.73 and changing absolutely nothing else. 3 tenths in a quarter mile is ALOT. That small of a change would not do that. You must have hooked better, engine cooler, less humidity a number of factors , but it could not be because of the gear change solely. Just my 2 cents
nope JUST a GEAR swap.. ran average 12.7's @ 108 with 3.55's 3 weeks later same track and conditions 3.73's ran a average 12.40 @ 112
NOTHING ELSE WAS CHANGED
What did you end up doing?
Agreed
No such thing as overkill.
Me personally, I would not change from a 3.55 to "just" a 3.73. I know in Camaro's (4th gens) going from 3.42 to 3.73 is not much of a difference. I put 4.11's in my Z (from 2.73's) behind an automatic which in the Fbody world was always considere "overkill". Loved every minute of it. Only thing that sucked? With a 3600 stall 1st and 2nd gears were useless unless I had DR's on.
3.31 is the standard equipment gear with a manual trans at least in the U.S. cars.
Verts have no optional gear.
A 4.10 gear will be overkill unless drag racing is all you want to do since the 6 speed has such a short first gear.
Going from a 3.55 gear to a 3.73 is such a small change as to be almost un-noticeable.
Blown motors act differently than N/A.
if the car was NA i agree..
corral day oct 2001 lebanon NY ( yes 2001) 3.55's 12.7 @108 average ant thats what car roughly averaged for a year prior to the gear swap on dr's 10 + passes, all day crossing trap 5000 rpm ish 4th
3 weeks later 3.73's added 12.4 @ 112 average on SAME dr's 54 all day.. 5400ish 4th and that what the car averaged up until i sold it.
im not trying to
believe what you want.. i was there you werent..
3.73 actually makes the car easier to drive and I save gas too. My old 2005 had 3.31 gears and my 1999 had the 3.08 set. I could never shift into 5th until 45-50. With the 3.73 in my 2010, I can shift into 5th earlier and can hold third for turns I used to shift into 2nd for. As a result, I've seen better mileage.
cant wait to get mine to ET and test it with DR's
i have a feeling ill be getting very close to my old GT if not faster.
street tires 13.0 - 12.8 with 1.9 - 2.0 60'
DR's 1.7's 60' 12.4's ish
I will be going to 373's in my 08 Saleen SS charged car Should be a blast. It should give me the feeling of acceleration I had in my 03 Terminator.....and from I have read, my gas mileage should not take a hit.
Rando
8/25/21 11:12 AM
9/24/15 08:15 PM
9/10/15 12:44 PM
