Axle 3.55 to 3.73 Worth it?
Old Apr 3, 2010 | 12:21 PM
VegasGold's Avatar
Canadian Manual Gt's come standard with 3.55 rear axle. We have the option for 3.73 for $500. Is it worth it? Will you notice anything? Or should I just buy aftermarket 4.10 gears?
I know the U.S Gt manual comes with 3.31 as standard. I would imagine a switch to 3.73 would be more noticiable than our option. Any input would be appreciated...
Old Apr 3, 2010 | 12:33 PM
m4reapr's Avatar
can't quantify if it's worth it, it's your money
for me with this car at this time i went for the most performance, i.e. 3.73s
here is from a thread i made called speed in gears about the mph/100rpm in each rear gear ratio/tire size/trans
so I input the various ratios available for the 2 transmissions offered into a gearing/mph calculator to give an idea of the speed@1000 rpm.
pick your motor, trans., tire size and ratio to see what rpm's you will be turning at any given speed.
MUSTANG GT
235/50/18 tires
MT ratio rpm 1st 2nd 3rd 4th 5th 6th
3.31 1000 7 10 14 19 24 38
3.55 1000 6 9 14 17 23 35
3.73 1000 6 9 13 16 22 33
245/45/19 tires
3.31 1000 7 10 15 19 25 38
3.55 1000 6 10 14 18 23 36
3.73 1000 6 9 13 17 22 34
255/40/19 tires
3.31 1000 7 10 14 18 24 37
3.55 1000 6 9 13 17 23 35
235/50/18 tires
AT ratio rpm 1st 2nd 3rd 4th 5th 6th
3.15 1000 6 11 17 23 30 37
3.31 1000 6 10 16 21 28 35
245/45/19 tires
3.15 1000 6 11 17 23 30 38
3.31 1000 6 11 16 22 29 36
Given the 7000 rpm redline:
MANUAL TRANS cars will cross the 1/4 mile in 4th gear.
AUTO TRANS cars will cross the 1/4 mile in 3rd gear unless it can exceed a 112mph trap speed.
Old Apr 3, 2010 | 12:40 PM
VegasGold's Avatar
Thank you for the information...
Old Apr 3, 2010 | 12:53 PM
stangfoeva's Avatar
MOTM Committee Member
I was building my GT yesterday with the salesman and he made it seem like you had to choose the 3.55 or 3.73. Isn't the 3.31 standard? What code do you put in?
Old Apr 3, 2010 | 12:58 PM
m4reapr's Avatar
if you are going with the standard rear end ratio nothing is put in only the transmission you are going with
Old Apr 3, 2010 | 12:59 PM
Ltngdrvr's Avatar
3.31 is the standard equipment gear with a manual trans at least in the U.S. cars.
Verts have no optional gear.
A 4.10 gear will be overkill unless drag racing is all you want to do since the 6 speed has such a short first gear.
Going from a 3.55 gear to a 3.73 is such a small change as to be almost un-noticeable.
Old Apr 3, 2010 | 01:04 PM
WaltM's Avatar
My SVO has 3.73 gears, while the GT has 3.55's. Can I feel the difference? yes, but I don't think that it's enough of a difference to justify the cost.
IMO? From 3.31 to 3.55, yes. From 3.55 to 3.90, yes. 3.55 to 3.73, no...
Old Apr 3, 2010 | 01:08 PM
stangfoeva's Avatar
Thank you!
I want the 3.73s, but in my circumstances for what I will use the car for and what I can afford, skipping the 3.73s and the brembo package is the smart thing to do...
Old Apr 3, 2010 | 01:16 PM
Dave07997S's Avatar
Can't compare the SVO to the GT, the 1st gear on the SVO is like 4.24:1 vs. a 3.35:1 and not to mention the torque curve of these motors are so different.
I agree though..3.55's to 3.73's are not worth the expense.
Dave
Old Apr 3, 2010 | 01:17 PM
Dave07997S's Avatar
Thank you!
Don't skip the Brembo package, heck that's really the only package at a minimum I would get.
Dave
Old Apr 3, 2010 | 01:29 PM
VegasGold's Avatar
Thank you for all your comments. You helped with my decision...Joseph...
Old Apr 3, 2010 | 01:33 PM
stangfoeva's Avatar
Dave
But Dave, my car will probably never see any road course or autox duty. I really only wanted the brembos for the wider tires, that way I could switch to the GT500 wheels with ease. The 245/45/19's won't fit the 19x9.5 wheels...
Old Apr 3, 2010 | 04:52 PM
pony racer's Avatar
Dave
dropped .3 in the 1/4 plus gained 4mph with my 95GT
Old Apr 3, 2010 | 08:11 PM
bpmurr's Avatar
If you are getting 3.55 gears standard I wouldn't make the switch. For US owners it's worth it to get the 3.73s over the 3.55 since it's the same price for both.
Old Apr 3, 2010 | 09:01 PM
Fugitive's Avatar
I was thinking the same so i am going to stick with 3.55's since they are standard here in Canada.
Old Apr 3, 2010 | 09:05 PM
Dave07997S's Avatar
There was more to it than the gear swap from 3.55's to 3.73's, I'm not disputing your numbers but you will be lucky if going from a 3.31 to a 3.73 will get you .3 or 4mph in the 1320.
Dave
Old Apr 3, 2010 | 09:09 PM
Dave07997S's Avatar
Oh I totally understand, its just I would still get it.
Old Apr 3, 2010 | 09:11 PM
bpmurr's Avatar
I had the dealer I bought my 2010 from re-spec their 2011 GTs. They were getting 3.55 gears but they changed them to 3.73 based on my recommendations.
Old Apr 3, 2010 | 09:13 PM
stangfoeva's Avatar
Well I'm really thinking about it now. Since the dealer agreed to invoice+holdback, its only a $609 difference between the brembo pkg and the regular 19"s ...... ........
Old Apr 3, 2010 | 09:26 PM
pony racer's Avatar
Dave
nope JUST a GEAR swap.. ran average 12.7's @ 108 with 3.55's 3 weeks later same track and conditions 3.73's ran a average 12.40 @ 112
NOTHING ELSE WAS CHANGED
