Accidents due to the 6-speed MT reverse gear not engaging.
#41
AzPete - No hard feelings Pete. I know it's my fault not the transmissions. I just thought it was a funny story. I know I was the one at fault. A lot of guys have a hard time admitting they did something wrong like if they don't drive stick perfect they're less of a man. I make mistakes all day long. Miss gears, up shift to soon and so on...
#42
One time when I was backing out in a hurry I thought I went from R to 1st, but actually went back into R. Luckily I noticed as soon as the car started rolling. Learned that you just can't rush between 1st and R.
I do still like the placement of R compared to other 6 speeds.
![Banghead](https://themustangsource.com/forums/images/smilies/banghead.gif)
#43
Spam Connoisseur
I got هَبوبed
I got هَبوبed
Dhawk1313- Haha, yeah, Pete is a cranky old leather neck I suppose. You would have thought I smashed his car instead of mine. He is more mad about it than me. I meant it as a light hearted topic and Pete is about to have his 3rd heart attack this year over it. Hey Pete, chill out my friend.
Dang....guess a guy cannot suggest things around here. Same points were posted by numerous others....and I do feel drivers ed would be helpful in today's world. Manual or automatic, it was taught to be easy on the brakes and gas to be sure the car was going in the direction you intended it to go.
Got the license in 1966, never lost it....not perfect by along shot but at least I don't name call.
Well....at least you removed the name calling...and I have no issues...you are the one with the negative comments....
![Sterb082](https://themustangsource.com/forums/images/smilies/sterb082.gif)
#45
I've never had a problem with any of my manual trans cars here, but I recall a visit to the UK where muscle memory tripped me up a couple of times. I had rented a five-speed manual and without thinking moved the shift lever toward my leg and forward. It was an 'oh crap' moment when I realized I was trying to start off in fifth gear.
#46
#47
#48
Yep, you are in the right-hand seat. The muscle memory comes in as a memory that first gear is close to your leg and forward. The same type of memory causes you to look up and to your right for the rear view mirror and find yourself looking out the window at the passing trees. It also causes you to use the left-hand steering column stalk to signal for a turn and find that you have turned on the windshield wipers. You get used to it all pretty quickly and then it's a hoot. As you approach a roundabout there are signs with three hash marks, then two, and then one. They indicate hundreds of yards to the entrance to the roundabout. For me they quickly became downshift points to fourth, and then third, and then second and blast around the roundabout (assuming it was clear). Great fun.
#49
#50
If your handy and it is still a issue, run a wire from the reverse lights to a light in the dash or under etc.. Then you would have a indicator letting you know your reverse is engaged.
#51
^ I was actually thinking of doing that, thought there'd probably be a connector with something for that more centrally (for auto trans, backup display mirror, etc.).
I like where R is, but would prefer it high right ("7") if it could be done. I have very often not been in reverse when I thought I was, but always caught it before moving. The R spring on mine seems very strong. My new habit (new for this car) is to double-check I'm in reverse. Not a problem, but a nanny indicator for this would be a lot more useful *to me* than the vast majority of them, I'd see this one several times a day.
Been driving stick since '78, this is my first "push down" reverse, though I encountered it in '79 in a French Renault and nobody told me, couldn't get out of the parking space for a long time lol.
#52
Maybe the spring is just still a litle stiff from not really being used all that much? Maybe the more you use it, the softer the spring will become.
#53
And by the way, I am for a variety of activities, ambidextrous. Having driven in the UK a number of times now I find that I can hop in a right-hand drive car and feel at home.
#54
#55
I've never had a problem with this. I like where reverse is positioned. The gears you are using when maneuvering into a parking space are 1 and R, so it's nice that they are close together.
Porsche now has a 7-speed manual and so does the 2014 Corvette. The Porsche shifter look like this:
R 1 3 5 7
.. 2 4 6
(Ignore the periods under R. Without it the alignment won't stay in place.)
The 2014 Corvette shifter looks like this:
1 3 5 7
2 4 6 R
In both cases, it's a reach to keep going back and forth between 1 and R. I think I would prefer one like this, if you're going to have 7 speeds:
R 2 4 6
1 3 5 7
Several years ago Porsche's 928 had a shift pattern like the one above but it only went up to 5.
R 1 3 5 7
.. 2 4 6
1 3 5 7
2 4 6 R
R 2 4 6
1 3 5 7
Gigantor
5/11/23 07:31 PM
Rando
8/25/21 11:12 AM
