5w20 to 5w30
Old Jan 23, 2015 | 04:39 AM
Stevedotmil's Avatar
I should have specified what I was concurring with. Thanks for calling me ignorant. I meant to agree with the warranty portion of this comment.
Old Jan 23, 2015 | 04:47 AM
Kestral's Avatar
The reason I even ask about the 5w20 vs. 5w30 oil in our 5.0 is frankly I guess I just don't feal comfortable with 5w20 weight oil in a high performance car. I am a bit old school on oil in that I was always told to go up a grade if you are working a car or truck like towing a camper or if you have a high performance car and plan to drive it hard. Although my thinking may be out dated you don't see many track or race cars running 5w20 weight oil now do you... Frankly I believe the 5w20 oil was to increase the overall fuel economy of a auto manufacture like Ford and I can understand why they do it esp when they prob have no more oil related failures running 5w20 then a thicker oil weight. It would be interesting to see over 100,000 miles if there would be any wear difference between running a 5.0 hard on 5w20 vs 5w30.
My mustang seems to run fine on the 5w20 oil no tick or noise and although I do wind it up now and then I feel it is nothing compared to the testing or beating Ford gave the 5.0 during it's development. On that note I still don't feel comfortable running the 5w20 so I will prob try some quality 5w30 this summer and most likely stick with that.
Old Jan 23, 2015 | 06:33 AM
It is your car. Run what you are comfortable running according to what you have had success with in your car experience. I used to run straight 40 weight in my aircooled Type 1 VW but that was because it was aircooled and needed the extra oil weight to help absorb the heat from the engine. That was a fully built high performance motor. Other guys ran something else with the same engine. I had good experience with it for the climate I was living in so that's what I ran. Do your own research and run what you want. On the net everyone is an expert. It doesn't happen very often on this particular forum but it still happens.
Old Jan 23, 2015 | 07:27 AM
2011 Kona Blue's Avatar
You should use whatever you feel comfortable with. My wife's 2005 Mazda calls for 5W20 weight oil. I have been using 5W30 weight oil for the past 10 years and at 133k miles the car runs flawless. Now, I'm not saying my engine would blow up or stop working if I had been using 5W20 weight.
5W20 oil has to do with CAFE regulations here in the US. The very same tight spec engine here in the US that calls for 5W20 weight gets 5W30 weight in Europe. Same car , same exact engine yet different oil weight! Europe doesn't have CAFE regulations!
Old Jan 23, 2015 | 10:49 AM
70monte's Avatar
5W-30 is not going to hurt your engine. The track pak cars that are supposed to run the 5W-50 supposedly have the same exact engine as the non-track pak cars that require 5W-20 so I would assume you could use anything in between and be okay.
Wayne
Old Jan 23, 2015 | 11:18 AM
tom281's Avatar
I'm doing mobile one 5w30 in my track pack car when it's due for its first oil change. I have no worries and it's super convenient for me, our local Costco carries it and our Bmw and Gmc both call for 5w30.
Old Jan 23, 2015 | 12:53 PM
Wayne
The track pac 5.0 and non track pac do have the same engine. No difference and has to do with suspension mods. If one has a track pac 5.0 and not racing then no need for the 5W50 weight because its just used as a non track pac way.
Then again, why would someone buy a track pac 5.0 and not track race? Of course that's none of my business. Ba ha ha ha. Stir pot
Old Jan 23, 2015 | 02:09 PM
xtc.inc's Avatar
5w20 is less viscous, and will flow more freely through the engine. Some people have developed the tick from using too heavy of a weight for their oil which resulted in poor circulation through the cams.
Old Jan 23, 2015 | 02:11 PM
xtc.inc's Avatar
Not only that but i spoke to several shop foremans at a few dealerships and according to the handbook you should be using 5w20. They strongly advised me to do so based on the coyote engine manual and i have not had any issues. Tick free so far.
Old Jan 23, 2015 | 02:22 PM
Respectfully, that doesn't make sense. If people are using too think of an oil weight how does the 5.0 with track pac get 5W50 weight? Why is the 50 weight not too thick on the same identical engine that calls for 5W20 weight by your logic
Old Jan 23, 2015 | 03:53 PM
GrabberBlue5.0's Avatar
Originally Posted by cdynaco
The ignorance you dweebs spout - and then repeat in another 6 months on yet another oil thread - is amazing.
I guess you know everything huh?
Old Jan 23, 2015 | 03:54 PM
I have zero faith in any "shop foreman".
Old Jan 23, 2015 | 03:56 PM
Yea no nice try. Not even close.
Old Jan 23, 2015 | 04:12 PM
5.M0NSTER's Avatar
The main difference is the Track Pack has an oil cooler, just like in the Boss. PT cars also have the larger Boss radiator.
Thicker oil like 50 weight heats up more, thus the cooler. And if I'm not mistaken 50 weight will eventually shear down to a 30 weight.
Old Jan 23, 2015 | 04:48 PM
xtc.inc's Avatar
This is what i was told by two techs and two different dealerships. I have no reason to make anything up. I asked them the same question regarding the track pack since there are no engine differences. They said running a heavier weight oil will reduce friction for heavily abused engines (ie frequent track day scenarios).
u
mad
brah
Old Jan 23, 2015 | 10:03 PM
SONICBOOST's Avatar
I am not an engineer nor am I an engine guru, so therefore I am going to use what is recommend. Always subjective but I'll take the odds.
Old Jan 23, 2015 | 10:26 PM
kylerohde's Avatar
Super. Another thread on this, really?
Old Jan 23, 2015 | 10:28 PM
Ba ha ha ha
Old Jan 23, 2015 | 10:34 PM
kylerohde's Avatar
Ba ha ha ha
You're a sick, sick man.
Old Jan 23, 2015 | 10:50 PM
  #40
We need more oil threads.
