5.0 power numbers leaked? 400hp, 360tq, 6 speed.
Old Apr 9, 2008 | 12:00 PM
SuperSugeKnight's Avatar
Originally Posted by buck
So the lineup were looking at is:
v6 base line
v6 TT 3.5
5.0 v8 GT
5.4 gt500
this sounds really good to me esp if the 5.0 is alum
I don't think it would be wise to use the 5.4 for the GT-500. If the standard GT is as good as FourCam states, it would run **** close the the GT-500. It might be better to TT the 5.0. Should be able to shave off 100 to 200 pounds of weight just with that.
Old Apr 9, 2008 | 12:01 PM
jayguy's Avatar
Well, he compared the weight of the 5.0 motored car with an all aluminum engine to the 5.4 GT500 now with it's cast iron block in one post. It is still 2 years away, but I'm gonna guess aluminum block and heads.
Old Apr 9, 2008 | 12:03 PM
2 years still. So the 2010 GT will have a 4.6L 3v and the 2011 will have the 5.0L?
Old Apr 9, 2008 | 12:08 PM
goesfast's Avatar
Once again, this engine is speculation and rumours. There are no hard numbers for the Mustang's application of it. But you will see an all-aluminum engine. Anything else is a step backwards.
Old Apr 9, 2008 | 12:13 PM
Boomer's Avatar
The GT500 will be more powerful than it is now.
Even IF they still use the same engine, remember the R/D is in it for up to around 600hp
I'm still sticking with the 400hp 5.0 Under 30k Mustang GT
Old Apr 9, 2008 | 12:15 PM
Mustang05's Avatar
Works for me
Old Apr 9, 2008 | 12:28 PM
Boomer's Avatar
Ok...around 30k... or under
haha
I don't really know the price...
Old Apr 9, 2008 | 12:35 PM
buck's Avatar
I had thought that the gt500 was projected to get a 15-20 hp boost but that was really it. It would be nice if they could switch the 5.4 over to alum... I could see a 5.0 TT being a possibility for the gt500 but somehow I doubt it. I would put good money though on the idea of a alum 5.0 400hp GT!
Old Apr 9, 2008 | 12:51 PM
Wolf's Avatar
Quote:
Originally Posted by JSnake
Any info on the next Gen Shelby or whatever special edition Stang for 2010?
"If you bleed blue you'll have a lot to be happy about in the coming years. "
What does bleed blue mean?
Old Apr 9, 2008 | 12:54 PM
Boomer's Avatar
Bleed blue = ford lova
It means good stuff coming down the line
ie: you want a mustang in 2010/2011+...its going to be kickin
Old Apr 9, 2008 | 12:55 PM
Moosetang's Avatar
Not so sure about the CGI...
I'd think AL before CGI
I'm not saying it WILL be CGI, I'm just pointing out that CGI rumors persist. And the TT 5L SE/GT-500 rumors would seem to reinforce the CGI possibility since it would be better able to handle forced induction. We know 5L, we know GDI, we're pretty sure on 400 hp, but while AL is likely I don't think we can say AL block for sure just yet.
Old Apr 9, 2008 | 01:01 PM
Wolf's Avatar
Thanks. I have no choice but to wait.
Old Apr 9, 2008 | 01:11 PM
Boomer's Avatar
I don't think we'll see a 5.0 TT in the near future...
I think its totally possible but not for the coming up 2010+
I can't see them not using the 5.4 for the GT500, when all the work is done for it already,
all they have to do is turn up the dial. Just hope they worked on getting the power to the ground.
Old Apr 9, 2008 | 02:19 PM
Well they did kill the Terminator engine after just 2 years of production. Well, except for the drift cars.
Old Apr 9, 2008 | 02:57 PM
Boomer's Avatar
Your right on that...
I just have a feeling....
Old Apr 9, 2008 | 04:01 PM
Topnotch's Avatar
Sorta Poetic...
My first Mustang was a 1985 Mustang GT with 210 HP out of a 302 HO topped by the 600 cfm Holley 4V including a racing-style roller lifter camshaft, stainless steel tubular exhaust manifolds and forged 8.4:1 pistons.
Looks like 25 Mustang Years later the 2010 GT will have a 302 with 400HP... sounds like a plan. Tuxedo Black w/ Chamois please!
Old Apr 9, 2008 | 05:00 PM
future9er24's Avatar
Old Apr 9, 2008 | 05:05 PM
max2000jp's Avatar
Would be sweet if it turns out to be true! An IRS option would be nice too.
Old Apr 9, 2008 | 05:17 PM
V10's Avatar
V10
The last rumors I saw said that it was unlikely we'd see CGI in gasoline engines. The problem is when the castings are made thinner to take advantage of CGI's strength to save weight NVH becomes a problem. Indications are Al blocks for gas engines.
Old Apr 9, 2008 | 07:41 PM
  #40
MustangFanatic's Avatar
Fourcam has actually been quoting those numbers for several months. The new 5.0L will likely offer both GDI and VVT so 400 hp isn't a huge stretch
