5.0 engine teardown at Livernois Motorsports
Pretty impressive peak flow numbers, did he happen to post any low or mid lift data? Thats where multi-valve heads really shine.
Administrator, Shop Manual PDF Poster, Parts Locator & Spam Bot Eliminator!!
Received 2,861 Likes
Here is Some 5.0 Info for you!
Enjoy,
KC
Enjoy,
KC
IIRC six sigma is just 5S with another S - Safety - added to the end. I am technically a green belt but I haven't touched that **** in a long time. Isn't it like sort, shine, spank, squeeze and swallow or something like that?
I hate 6S. I hate AirSpeed too, that's the gay version the Navy came up with for us. If I ever hear the word "Kaizen" again...
We're getting closer!
We finalized our piston design and we're working on a standard stroke and stroker crankshaft.
Piston specs:
![](http://i540.photobucket.com/albums/gg324/LivernoisMotorsports/50/Picture007.jpg)
![](http://i540.photobucket.com/albums/gg324/LivernoisMotorsports/50/Picture010-1.jpg)
![](http://i540.photobucket.com/albums/gg324/LivernoisMotorsports/50/Picture006.jpg)
![](http://i540.photobucket.com/albums/gg324/LivernoisMotorsports/50/Picture005.jpg)
![](http://i540.photobucket.com/albums/gg324/LivernoisMotorsports/50/Picture004-1.jpg)
Regards,
Rick LeBlanc
Piston specs:
- Custom design crown configuration for new 5.0 style heads
- Increased top and second fireland thickness .300+ Top .200 +2nd
- Standard 1.5mm, 1.5mm, 3.0mm ring package heights with steel top ring
- Integrated notches allow use of factory oil sprayer
- Revised oil control/drainback slots work with factory oil spray system and oil control ring
- Inner pin boss designed around Manley H-Beam style rod
- Full pin oiling
- Radiused valve pockets
- High Compression version (11.5-1)
- Low Compression version (10.0-1)
- Livernois Exclusive 2.0 skirt profile (This encompasses many changes, revised shape of skirt, revised sizing and fit points on skirt) Improved design for better wear and durability while also allowing for increased stability.
Regards,
Rick LeBlanc
I am Shauny Clause
MOTM July 2010 Winner
its called QR code it was invented by Denso.
Its a fast reading replacment for the bar code
http://www.denso-wave.com/qrcode/qrfeature-e.html
That new piston looks bad-***! Now that you guys have had some time to play with the tuning, I cant wait to see what stronger internals and upgraded valvetrain components can yield N/A. I can see a 8500+ RPM screamer coming...
![Worship](https://themustangsource.com/forums/images/smilies/worship.gif)
I am Shauny Clause
a certain engineer (that comes over to your house all the time and eat's at your BBQ's) says the ECU cant handle that high of RPM, fuel delivery gets all weird as the processor cant keep up with senor data from the crank and cam and they get outta phase
Did this certain BBQ-eating engineer say what if anything Ford was hoping to do about it?
#40
I am Shauny Clause
