401A Shift Knob - What kind of loctite on threads?
Old Feb 26, 2010 | 11:05 PM
Adam's Avatar
Question 401A Shift **** - What kind of loctite on threads?
I'm installing a 401A Bullitt shift **** in my 400A GT. At the very tightest position the numbers aren't in proper alignment. I have to back off a tad which makes it just a little looser than I'd like. What color loctite would you recommend to hold it in place while still being able to remove it without too much difficulty? Thanks.
Old Feb 26, 2010 | 11:23 PM
eci's Avatar
eci
blue
Old Feb 27, 2010 | 07:07 AM
Skotty's Avatar
You could also consider using a spacer/shim, if that appeals to you.
Old Feb 27, 2010 | 08:23 AM
825LTRGT's Avatar
Grabber Pony makes a nice jam nut.
Old Feb 27, 2010 | 10:10 AM
Adam's Avatar
Originally Posted by eci
blue
That's what I figured. Red is permanent and Green is penetrating. A dab of blue would do the job.
Old Feb 27, 2010 | 10:19 AM
Adam's Avatar
The shifter threads are 12mm x 1.25. However, with the 401A Bullitt shift **** it doesn't leave any exposed threads to use a jam nut. See the picture below.
The shift boot looks odd because my 401A boot hasn't arrived yet. It should be here Tuesday.
Old Mar 1, 2010 | 02:35 PM
stangfoeva's Avatar
MOTM Committee Member
Be sure to post pics of the install
I'll probably be doing the same thing.
Old Mar 1, 2010 | 09:37 PM
Ditto...
Old Mar 30, 2010 | 03:14 PM
stangfoeva's Avatar
Ditto...
Any updates on this?
Old Mar 30, 2010 | 03:29 PM
Adam's Avatar
Today I received the 401A shift boot (Ford Part #: AR3Z-7277-B, list price $54). I took some pictures along the way in case anyone was curious.
Center compartment removed from car. 401A shift boot to the right still in a plastic bag.
401A shift boot by itself.
Circled in red are the plastic tabs holding the shift boot in place
Old 400A shift boot removed, along with the cup holders. The cup holder is only held in place by four screws, removing it made it easier to get the boot out.
401A shift boot in place. Center compartment ready to be reinstalled.
All done!
Old Mar 30, 2010 | 03:45 PM
stangfoeva's Avatar
Wow perfect timing Adam and nice install!!
Can you tell us what tools are required and how long/difficult was the whole process?
Old Mar 30, 2010 | 06:48 PM
Falchion's Avatar
Thanks for the pics!
That seems like a lot of work? I'm glad I got the 401A!
Old Aug 23, 2010 | 08:53 PM
jacostang's Avatar
Thanks guys! I had to get the 402A Package but really wanted this shifter and now I can you guys rock!!
Old Aug 24, 2010 | 06:57 AM
Modshack's Avatar
Cut a few little carboard circles and drop down the **** hole to use as shims. Adjust thickness so the **** aligns when fully tightened.
Old Sep 8, 2010 | 11:26 AM
m4a1mustang's Avatar
WIN! This is what I'm doing tonight. I'm tired of looking at my upside down ****.
Old Sep 8, 2010 | 12:40 PM
Adam's Avatar
It aligns perfectly without any kind of shim. Twist harder.
Old Sep 8, 2010 | 01:41 PM
That's what she said?
When I twist harder it does not sound very good. I can hear it scrape across the finisher on the shift boot.
Old Oct 8, 2010 | 02:30 PM
coyoteugly's Avatar
All done!
This is a great post. I just ordered the boot and my shift **** and this is a great reference. Thanks
Old Oct 8, 2010 | 02:39 PM
Modshack's Avatar
You may be out of luck here. Since that post, the part has been changed and now has a chrome plastic ring at the top that does not mate to any of the aftermarket adapters. You may be forced to use the Factory **** ($$$) to make it all work..
Old Oct 8, 2010 | 02:41 PM
Adam's Avatar
Uhh, what? The 400A shift boot has a plastic ring - but the 401A shift boot does not. Hence the reason I had to buy a 401A shift boot for my 400A car. If you want the 401A shift **** you need the 401A shift boot.
