3:73 test drive - rpm's at 60 mph - no response
Old Jul 2, 2011 | 10:40 AM
tetstang's Avatar
Hey All,
Somewhere in this forum, I found an xls that tabulated rpms with respective final drives. I test drove a 2012 GT Premium-Brembo-3:73 yesterday and
at 60 mph it tached 2000 rpm in 6th gear
I stomped it to the floor, and the car barely responded, . . . nada. Had to downshift to get anything.
The tach numbers I saw don't seem to match what I find in various posts about the same setup. And, I wonder about no response at 60mph, floored with 412 hp . . .
What are some of you guys with stock cars taching at 60 mph ?
Response in 6th gear?
Old Jul 2, 2011 | 10:52 AM
11SHELBYGT500's Avatar
What exactly did you expect to happen in an overdrive gear? LOL
Old Jul 2, 2011 | 10:56 AM
adrenalin's Avatar
Old Jul 2, 2011 | 11:06 AM
TheNewPony's Avatar
You usually have to be going about 65-70 in 6th to have much response. It's an overdrive gear so there won't be any power whatsoever.
Old Jul 2, 2011 | 11:22 AM
Five Oh Brian's Avatar
Originally Posted by tetstang
Hey All,
My '11 Brembo GT has 3.73's and tachs just under 2000 rpm's at 60 mph. These motors make tons of power at high rpm's, but under 2000 rpm's there is little power, so you need to downshift to get into the powerband.
Modshack's Avatar
2000 RPM's is 66.3 MPH.
6th is a steep overdrive ratio, not meant for acceleration. (0.65 for sixth, 1.00 for 5th)
Based on the chart I have, at 70MPH
6th = 2111 rpm's
5th = 3248 rpms
Downshift to 5th to put it in the sweet spot.
Old Jul 2, 2011 | 03:40 PM
tetstang's Avatar
I knew it was overdrive, but I didn't expect dead flat nothin'. Just put it out there to see what others are experiencing.
Old Jul 2, 2011 | 04:38 PM
kn7671's Avatar
Yep, that's perfectly normal. The overdrive in American cars is completely different than foreign cars, and is also different from 4cyl or 6cyl cars. Also, if you're used to any type of turbo or supercharged car, there will be a big difference between those and naturally aspirated cars.
This is nothing new, every manual tranmission V8 powered Mustang since 1984, first year of the 5-speed and overdrive gear as we know it, has been exactly like this.
Now if you were driving an Automatic 5.0, this obviously would not have been the case, as it would have dropped to 3rd or 4th gear at 60mph.
Old Jul 3, 2011 | 01:59 AM
tetstang's Avatar
It's alright. I like shifting anyway . . . . I'll admit, I'm used to turbos lately - even my turbo diesel truck pulls in 6th gear (yep, it's a manual).
Old Jul 3, 2011 | 07:26 AM
HoosierDaddy's Avatar
Legacy TMS Member Moderator
I may be going out on a limb but this could answer the age old question of why cars have more than one gear.
Old Jul 3, 2011 | 09:00 AM
karman's Avatar
Talking
LOL
Old Jul 3, 2011 | 12:15 PM
jimmbbo's Avatar
I usually cruise at 75 (80 if no other traffic ), and have enough power in 6th to pass easily on flat ground, but I don't mash the pedal down, I just start pressing it... need to downshift to 5th on an incline, or if "expedited" passing is required...
Evil_Capri
Aug 27, 2015 01:08 PM
cloud9
GT350
Aug 18, 2015 01:34 PM
trackpack13gt
Aug 8, 2015 11:23 AM
Bullitt 3309
Aug 2, 2015 10:20 PM
Jul 30, 2015 06:47 AM
