2014 GT - inconsistent power?
Old Mar 12, 2013 | 08:16 AM
fdesalvo's Avatar
Maybe it's poop gas, erroneously labeled as 91. Maybe it's not.
I’m experiencing inconsistent power when accelerating. Sometimes, the car really throws me back into the seat and sometimes it’s just all grunt with no torque. What could this be?
TIA
Old Mar 12, 2013 | 08:51 AM
PaxtonShelby's Avatar
If you haven't been fooling with anything it sounds like the car might be compensating for weak gas. I'm going to have to start paying attention to the specs of the gas in my area.
Old Mar 12, 2013 | 09:14 AM
fdesalvo's Avatar
Yah, probably is weak juice. I'll experiment with different gas stations until I find one that's serving up the fun stuff.
Old Mar 12, 2013 | 09:22 AM
JMac's Avatar
Somebody had a link in one of the threads about a month ago suggesting only using stations that are designated part of the Top Tier Gasoline group.
http://www.toptiergas.com/retailers.html
Old Mar 12, 2013 | 10:19 AM
tukatz's Avatar
I rarely buy gas from a station brand that is not on the Top Tier list.
Old Mar 12, 2013 | 10:21 AM
SONICBOOST's Avatar
No AM PM??
Old Mar 12, 2013 | 11:01 AM
CubedStang's Avatar
I usually go with Shell or Exxon, but also Sunoco pretty frequently. I'm surprised Sunoco isn't in the Top Tier list.
Old Mar 12, 2013 | 11:04 AM
fdesalvo's Avatar
LOL Sonic
JMac - thanks for the heads up
Old Mar 12, 2013 | 11:40 AM
Xar's Avatar
Xar
I use 76 or shell exclusively and it works great every time.
Old Mar 12, 2013 | 02:15 PM
Stjayp36's Avatar
TIA
Thinking outside the box - Is the traction control off?. Straight line with equal wheel spin or none it will squat and rip. If you goose it on a 90 deg corner like at the end of the street. If the traction picks up on you lifting 1 tire and spinning only 1 tire it will cut the fuel input to equal wheel spin. If you want to play on corners from a stop you may need to turn off the traction.
Old Mar 12, 2013 | 04:48 PM
Ethanjbeau's Avatar
Shell or Mobil. Never anything else. I'll go out of my way to put that gas in.
Old Mar 12, 2013 | 05:23 PM
Dozertmc's Avatar
If you don't run a lot of gas often I would put in a stabilizer to minimize the ethanol loss and that may solve your problem.
Old Mar 12, 2013 | 08:12 PM
MARZ's Avatar
Swamp Donkey Aficionado
I'm with you, CubedStang. Sunoco is among the the few local places from whom I purchase gasoline. I guess, like you, I'm sticking with Shell or Exxon in the future.
Old Mar 12, 2013 | 08:31 PM
Moustang's Avatar
I was going to say the same thing, but take it a step farther.
Is Advancetrac off? There are 3 different systems there that can limit fuel and apply brakes depending on what the sensors are detecting. Traction Control is the most obvious, especially in a straight line, but Yaw and Roll Control could also kick in if one tire grabs and the other doesn't.
Old Mar 13, 2013 | 07:55 AM
fdesalvo's Avatar
Resolved! Bad gas. Thanks for the input fellas.
Rando
Aug 25, 2021 11:12 AM
Gill5oh
Oct 6, 2017 10:50 PM
RCooke08GT
Feb 19, 2017 03:03 AM
