2014 Fog Light Adjustment?
Old Jun 22, 2013 | 07:36 AM
elkk's Avatar
It seems my LED Fog Lamps irritate oncoming drivers when used with my headlights. I am wondering if they are aimed to high or if oncoming drivers just assume my brights are on because there are 4 headlights on my GT at that time. Are there any Fog Lamp adjustments? Does anyone else experience this?
Old Jun 22, 2013 | 08:47 AM
"XLR8IN"'s Avatar
I get that all the time. most of my driving that I do is at night and I would say in a 20 mile trip to work I get flashed atleast 5 times a night and when they flash me (b/c they think I have my brights on) I give em' the real brights and they turn their brights off. Don't know if they adjust though.
Old Jun 22, 2013 | 10:39 AM
Its because the grill mounted lights are NOT fog lights. Fog lights are small, mounted low, so as to see under the fog.
You are turning on the driving lights - which is blinding to oncoming traffic.
Driving lights:
Fog lights:
Old Jun 22, 2013 | 11:39 AM
elkk's Avatar
Driving Lights? Are you sure.... I can't find any mention of them being called driving lights.
Page 83 of Owners Manual
The fog lamps can be turned on when the lighting control is pulled toward you and in the headlamps, parking lamps or autolamps positions. The fog lamps will not operate when the high beams are active.
Page 257
Replacing Fog Lamp Bulbs (GT)
Your vehicle is equipped with LED fog lamp bulbs. It is designed to last
the life of the vehicle. If replacement is required, it is recommended that
you see your authorized dealer.
Also mentioned on the Window Sticker:
Front Fog Lamps
Also Noted on the Sales Brochure
LED Fog Lamps
Old Jun 22, 2013 | 11:44 AM
Have you turned those lights on in a fog bank or blowing snowstorm? They'd be worse than high beams. Fog lights are low to cut under the cloud bank.
Regardless of Ford's adopting the 'fog light' tag in the OM that the current crop of Mustang owners keep pushing, they are mounted high and aimed further so as to see waaaay down the road at high speed night driving. Think LeMans.
That's why you're getting flashed by oncoming drivers. And compare the location of fog lights with every other manufacturer. Fog lights are always mounted low and less bright than headlights (and driving lights).
The grill lights have never been fog lights since they were introduced back in the day.
Old Jun 22, 2013 | 12:37 PM
rriddle3's Avatar
They're not truly either one. They strike the road surface too close to the front center of the car to be real driving lights, and are not mounted low enough to be effective fog lights, but they look cool so I tinted mine yellow.
Old Jun 22, 2013 | 05:04 PM
elkk's Avatar
I was just informed: "Yes, there are height adjustments on your fog lamps. Pull the large plastic radiator cover and you should see an adjustment screw on each lamp housing. Park about 8' from a garage wall or other surface with your fog lights ON. Adjust lamps by turning adjustment screws equally. It shouldn't take many screw adjustment revolutions to drop them to a less glaring level."
Old Jun 22, 2013 | 07:36 PM
lsxjunkie's Avatar
Me too. Yellow actually does cut through the fog.
Old Jun 24, 2013 | 09:57 AM
rriddle3's Avatar
What is the source of the information?
Old Nov 21, 2013 | 09:30 AM
monkeyonback's Avatar
I'm getting the high beam warning from passers by with just my regular head lights on. Any body else have this problem? I just bought the car new last night. How difficult is it to adjust them?
Old Nov 21, 2013 | 12:57 PM
mfc133's Avatar
I've driven through heavy fog a few times, they are remarkably useless as actual fog lights. But they are nice when you're driving on a really dark road that has no street lighting. A dark road is something I encounter much more often than fog so I like them just as they are. Plus I think the lights in the grille look good, I don't like the GT with the fog light delete grille.
Old Nov 21, 2013 | 01:05 PM
5.M0NSTER's Avatar
+1 on all 4 accounts.
Old Nov 21, 2013 | 03:27 PM
elkk's Avatar
I have made this adjustment on the driving / fog lights of my 2014 GT.
Old Nov 22, 2013 | 05:48 PM
lsxjunkie's Avatar
Me too. Nice yellow rectangles on the ground in front of the car now.
Old Nov 22, 2013 | 09:26 PM
Michael Broadway's Avatar
Yours must be adjusted differently than mine, because mine are aimed very low and illuminate the area right in front of the car.
Old Dec 7, 2013 | 05:57 PM
skramblr's Avatar
One thing that I didn't see posted, in many states (like here in Oregon) the fog lights are treated like headlight high-beams. They must be turned off when approaching oncoming traffic. So if you have them on you'll often get flashed by oncoming traffic. Also, I got pulled over by a traffic cop for having them on, so take notice. I had no clue. I just got a warning and the obligatory 'I used to have a mustang' story.
Old Dec 7, 2013 | 06:40 PM
Ltngdrvr's Avatar
If they truly were "driving" lights then they should work with the high beams. Ford intends them as "fog" lights and as such only work with the low beams.
Either way, they are mostly cosmetic.
Diode Dynamics
Jun 12, 2018 03:26 PM
Diode Dynamics
Feb 28, 2018 09:37 AM
defiance772
Oct 21, 2015 09:37 AM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
Earlsays
Aug 5, 2015 07:10 AM
