2013 windshield fluid issue
Old Oct 21, 2013 | 06:25 AM
apdmustangnick's Avatar
anyone else having an issue with the windshield wiper fluid not coming out?
Old Oct 21, 2013 | 11:51 AM
AzPete's Avatar
The fluid tends to dry out in the tubes and create a blockage. This is first developed at the small opening on the hood where the fluid is sprayed to the windshield. Sometimes a small pin inserted into that hole will be enough to open things up. I also.found that if I mix the premixed fluid with about 1/3 more distilled water, it still works good and does not seem to clog as fast.
Of course, you may want to see your dealer in case anything else is a problem like a hose pinched or the pump or switch not working.
Old Oct 21, 2013 | 12:05 PM
Ltngdrvr's Avatar
Does the pump run when you hit the button?
That would be the first thing I'd check, assuming that there is plenty of fluid in the bottle.
Old Oct 21, 2013 | 01:15 PM
fixed it!!
Expensive car like a mustang and they use a plastic hose for the fluid. If it pinches just a bit, it snaps..
Old Oct 23, 2013 | 10:44 AM
Horspla's Avatar
Diluting the washer fluid with water is not advisable if you live in a colder climate. The fluid will likely freeze when it gets cold which could potentially crack the reservoir and/or destroy the plastic pump. If you want to dilute it with anything use denatured alcohol or isopropyl alcohol. Neither will damage your paint, both have a lighter viscosity than the fluid and both will keep the fluid from freezing.
John
Raynier Leonardo
'10-14 Exterior Modifications
27
Mar 2, 2017 12:08 AM
JonsMustang
Mar 5, 2016 05:44 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
Grabber5.00
Sep 13, 2015 06:53 AM
Linkspure
Sep 12, 2015 06:33 PM
