2013 Cluster Lights Flashing
Old May 7, 2013 | 09:51 PM
dmhines's Avatar
Recently put a 2013 Cluster in my 2012 Mustang.
I notice that when I open the door the entire cluster FLASHES before the halo lights illuminate. Does it do this in 2013 Mustangs too? Or is something in my 2012 making it do this??
Here is example of me opening door.
Old May 8, 2013 | 06:21 AM
Bucko's Avatar
I found several unexplained things that happened when I exchanged the cluster of my 2005 Ford F150 STX with that of a FX. The FX model cluster had a tach; my STX cluster did not. When I swapped them out, the dome lights did not work anymore; the door open chime no longer worked; the information center displays were gone.
No telling what small changes were made in the cluster between years. Many of the guage functions are fed via the ECU now.
What did you gain with the 2012 to 2013 cluster swap?
Old May 8, 2013 | 06:40 AM
dmhines's Avatar
Nicer overlay and the cool LCD display in the middle .... No .. track apps does not work .. seems the Accelerometer is in the 2013 PCM.
Old May 8, 2013 | 07:49 AM
SoFlaBoss's Avatar
Dan, I just went to my garage and opened the door, and my 2013 does the same FLASH. I never noticed that before. I guess it's normal.
UPDATE: When I took my phone to record it on video it wasn't happening. I was sitting in the seat this time and just opened the door like before. ..strange
Old May 8, 2013 | 07:51 AM
dmhines's Avatar
Thanks! Appreciate it ... wanted to make sure something wasn't shorting out ...
Old May 8, 2013 | 08:11 AM
SoFlaBoss's Avatar
Did you see my update above. It doesn't always FLASH. ..but it does happen.
Old May 8, 2013 | 08:14 AM
dmhines's Avatar
LOL .. yes .. I did same thing. I went to record it the first time and it didn't happen. I then locked and unlocked the doors .. let the retained power go away .. and it happened again.
It also flashes if I reach into my window without opening the door and POP the Trunk from the console.
Old May 8, 2013 | 10:10 AM
Bucko's Avatar
That sounds like a motion detector for the alarm system, but I doubt it's set if your reaching through an open window.
Too bad the trac apps is not working. Does it at least light up with any display?
While the needle type guages are not the most accurate for severe reliable indications, I prefer them over digital readouts; you get used to the needle position of a guage when "all is well". With digital readouts, you sometimes have to think for a brief moment if the readout is good/within specs. Nit picky for sure.
Maybe someone will come out with a way to get the trac apps to work on the earlier Mustangs.
Old May 8, 2013 | 08:46 PM
racksteris's Avatar
My car does it. Its normal, Others have posted this before.
Old May 9, 2013 | 05:14 AM
the5's Avatar
Mine too
Old May 9, 2013 | 07:45 AM
Hadtohaveit'13's Avatar
Mine too. It's normal
Old May 9, 2013 | 06:15 PM
Dineau's Avatar
Mine as well !
Old May 10, 2013 | 03:58 AM
Siber Express's Avatar
Both opening the door and the trunk, normal.
Raynier Leonardo
'10-14 Exterior Modifications
27
Mar 2, 2017 12:08 AM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
Grabber5.00
Sep 13, 2015 06:53 AM
Linkspure
Sep 12, 2015 06:33 PM
