2013 California Special Wheel Weights
Does anyone know what the stock california special rim weights are? Can't seem to find it anywhere online and was looking around for aftermarket rims to compare in weight, but don't want something significantly heavier to add to the unsprung weight.
NacsMXer,
I have the exact same car as you and was wondering if you upgraded to lighter or heavier rims for your CS and if you could tell a difference. The stock rims and tires are 61 or so pounds with a 28lb stock tire which means if I got a 27 pound tire with a one pound heavier then stock rim i'd be breaking even, but the rear rims I'm looking at (Shelby CS1), are 40lb's in the rear making each rear tire and rim close to 69 pounds. That makes each side 8-9 pounds heavier in the rear. Does anyone know if i'd be able to tell that much of a weight difference?
NacsMXer,
What I noticed more, was the huge handling improvement over the pedestrian Pirelli P-Zero 245/45/19's.
I found this to be interesting for reference: http://teamspeed.com/forums/aventado...orsepower.html
They found that a 4lb increase in wheel weight resulted in a loss of 2 HP/2 ft-lbs. Yes, a difference in the wrong direction, but are you really going to notice that a whole lot?
The cast alum 19" rims on late model Mustangs are usually right around 31lbs as previously stated, the wider staggered rear rims are a little more. I debated spending near 2k on new Forgestars, but instead opted for Ford Racing rims for my Boss as they are just what I need for street use.
I'm looking to pick up the shelby cs1 wheels which even though i'm going with a wider front and rear tire, the front tires stay the exact same weight as stock, but the rears only jump up 7lbs a piece. Again not great, but i'm also upgrading to 6 piston brembo's which apparently are slightly lighter then stock rotors and calibers.
I was also looking at either a 4 or 6 piston Stoptech kit with 2 piece rotors which are surely going to be lighter than the stock GT brakes.
Mr. Sparkle
Aug 21, 2015 10:10 AM
