2013 5.0 Engine Problem Only 10k Miles
Old Jun 9, 2013 | 12:28 PM
treborwd22's Avatar
So just within the last week I have been hearing a ticking sound at low RPMs that goes away once I hit 2000 RPMs. I noticed that it takes 5 or so minutes for the ticking sound to start and it does not happen at idle.
Went to my local Saturday Car meet last night and while backing into my parking space the ticking sound was bouncing off my friends Boss 302 who was parked next to me. It's kind of embarrassing if you ask me. A few of the guys also noticed the ticking sound and gave me their opinion. I just wanted to hear if anyone has been having the same issue? I will be taking it in to my dealer on Tuesday.
Old Jun 9, 2013 | 04:06 PM
TheReaper's Avatar
A video or sound clip would be nice.
Old Jun 9, 2013 | 04:21 PM
steven46746's Avatar
Sounds like tick tick tick tick tick tick tick.
Old Jun 9, 2013 | 04:50 PM
Sounds like a sticky hydraulic lash adjuster.
Old Jun 9, 2013 | 05:28 PM
Depwraith's Avatar
Are you by chance using a different brand/weight oil than that recommended by Ford?
Old Jun 9, 2013 | 06:22 PM
A couple of car enthusiasts have listened to mine and said it could be the injectors making my noise. Going by my dealership tomorrow, pray for me
Old Jun 9, 2013 | 06:55 PM
TheReaper's Avatar
You had clicking in your original post. That's not the same as ticking.
Old Jun 9, 2013 | 08:38 PM
I'm not OP
Old Jun 9, 2013 | 08:49 PM
TheReaper's Avatar
I'm not OP
Oops........ My bad.
Old Jun 9, 2013 | 11:38 PM
Supra's Avatar
mine ticks too. seems pretty common
Old Jun 10, 2013 | 06:25 AM
FordService's Avatar
Hi guys,
I recommend you make an appointment with your dealers to get them checked out. Then, PM me with your VIN, dealer, full name, mileage, and best daytime number so I can escalate this to the customer service managers of your area.
Deysha
Old Jun 10, 2013 | 08:24 AM
treborwd22's Avatar
I just had a Full Synthetic Valvoline 5w20x8qt change on 6/4/13
Not sure if this has anyting to do with the noise but when the service tech started up my car after the oil change it would not start. It took a few times for the engine to turn over. Once it started up everything seemed fine.
Old Jun 10, 2013 | 08:30 AM
Depwraith's Avatar
I've heard issues from not using the Ford oil, which is why I asked. Never understood why people use different oil than what's recommended by the people that built the motor...
Old Jun 10, 2013 | 08:31 AM
treborwd22's Avatar
Just because it seems pretty common does not mean its a good thing.
Old Jun 10, 2013 | 08:42 AM
treborwd22's Avatar
And what's wrong with the oil I used? As long as the viscosity of the oil is 5w20, there is no harm in not using motorcraft oil.
Old Jun 10, 2013 | 02:24 PM
wanted33's Avatar
Injectors maybe. The 5.0L in my F-150 (and all the rest as I have read) are pretty loud. However, I haven't heard the tick in the Wifey's 5.0L.
Yeah, I just read this. Kind of a sorry excuse for an answer. Hope it's something simple for you. Keep us posted.
Old Jun 10, 2013 | 03:12 PM
dmichaels's Avatar
Because there are different oils that are often better suited for particular applications. Oil analysis of the motorcraft seems to indicate it breaks down more quickly than other oils. I will be doing oil analysis on my car after oil changes. The motorcraft oil is fairly pricey too from what I have seen. Would much rather use an alternate oil that has good analysis history, although it seems with my track pack mustang I am a bit limited with oil choice without potentially causing potential warranty issues
Old Jun 10, 2013 | 04:07 PM
Took it by the dealer and they said all they would do is compare it to another 5.0 so........took it by friend's on the way home, he's a mechanic and a ford guy. He said it sounded like a cam phaser, it was probably normal, and that his truck does the same thing. Not sure what to do.
Old Jun 10, 2013 | 04:38 PM
max5ive0's Avatar
Is this a Track Pack car requiring 5w50? Might be an issue at temp
Old Jun 10, 2013 | 04:48 PM
That's curious. Because the cam phaser was more problematic on some 4.6L & 5.4L where the VCT is all hydraulic.
But since the 5.0 TiVCT is cam torque actuated, there isn't the same level of hydraulic action.
