2013 5.0 Engine Problem Only 10k Miles
So just within the last week I have been hearing a ticking sound at low RPMs that goes away once I hit 2000 RPMs. I noticed that it takes 5 or so minutes for the ticking sound to start and it does not happen at idle.
Went to my local Saturday Car meet last night and while backing into my parking space the ticking sound was bouncing off my friends Boss 302 who was parked next to me. It's kind of embarrassing if you ask me. A few of the guys also noticed the ticking sound and gave me their opinion. I just wanted to hear if anyone has been having the same issue? I will be taking it in to my dealer on Tuesday. |
A video or sound clip would be nice.
Originally Posted by TheReaper
(Post 6637829)
Sounds like a sticky hydraulic lash adjuster.
Are you by chance using a different brand/weight oil than that recommended by Ford?
A couple of car enthusiasts have listened to mine and said it could be the injectors making my noise. Going by my dealership tomorrow, pray for me;)
Originally Posted by steven46746
(Post 6637837)
Sounds like tick tick tick tick tick tick tick.
(Post 6637937)
You had clicking in your original post. That's not the same as ticking. |
(Post 6637979)
I'm not OP
mine ticks too. seems pretty common
Originally Posted by treborwd22
(Post 6637735)
(Post 6637899)
Originally Posted by Supra
(Post 6638040)
I recommend you make an appointment with your dealers to get them checked out. Then, PM me with your VIN, dealer, full name, mileage, and best daytime number so I can escalate this to the customer service managers of your area. Deysha |
Originally Posted by Depwraith
(Post 6637870)
Not sure if this has anyting to do with the noise but when the service tech started up my car after the oil change it would not start. It took a few times for the engine to turn over. Once it started up everything seemed fine. |
(Post 6638135)
I just had a Full Synthetic Valvoline 5w20x8qt change on 6/4/13 Not sure if this has anyting to do with the noise but when the service tech started up my car after the oil change it would not start. It took a few times for the engine to turn over. Once it started up everything seemed fine. |
(Post 6638040)
(Post 6638138)
I've heard issues from not using the Ford oil, which is why I asked. Never understood why people use different oil than what's recommended by the people that built the motor...
Injectors maybe. The 5.0L in my F-150 (and all the rest as I have read) are pretty loud. However, I haven't heard the tick in the Wifey's 5.0L.
Yeah, I just read this. Kind of a sorry excuse for an answer. :wacko: Hope it's something simple for you. Keep us posted. |
(Post 6638138)
Took it by the dealer and they said all they would do is compare it to another 5.0 so........took it by friend's on the way home, he's a mechanic and a ford guy. He said it sounded like a cam phaser, it was probably normal, and that his truck does the same thing. Not sure what to do.
Is this a Track Pack car requiring 5w50? Might be an issue at temp
(Post 6638376)
But since the 5.0 TiVCT is cam torque actuated, there isn't the same level of hydraulic action. |
